86 Crx si leaking coolant...
Old Apr 19, 2004 | 09:59 PM
topgun2001's Avatar
Default 86 Crx si leaking coolant...
my 86 crx si is leaking coolant from the backside of the motor near the oil filter.. no idea what it is... any ideas would be appreciated
Old Apr 19, 2004 | 11:04 PM
c jackson's Avatar
threes
Default Re: 86 Crx si leaking coolant... (topgun2001)
could be a number of things. just jack the car up, dry/clean it up as much as possible, turn on the car and find where it drips out of.
Old Apr 20, 2004 | 07:13 AM
blah13's Avatar
Default Re: 86 Crx si leaking coolant... (c jackson)
Water pump, coolant hose that runs from the pump to the thermostat, possibly even intake manifold hose leaking and running down the back. Do like jackon said, clean it up, start it and get under there.
Old Apr 20, 2004 | 07:16 AM
skribs89si's Avatar
its probably the thermostat housing, i had the same problem on my 89 ef hatch its on the back of the motor near your left side of the intake manifold
Old Apr 20, 2004 | 07:35 AM
Live_Love_Burn_Die's Avatar
Default Re: (skribs89si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribs89si &raquo;</TD></TR><TR><TD CLASS="quote">its probably the thermostat housing, i had the same problem on my 89 ef hatch its on the back of the motor near your left side of the intake manifold</TD></TR></TABLE>
it might be that..but i had the same problem and it was the pipe that runs from the thermostat housing across the back of the motor, that had crack and it was a constant drip, pretty bad.
90blkteg
May 6, 2008 12:20 PM
TrueUntilDeath.com
Jan 25, 2008 03:38 PM
crxvtecturbo
Jul 23, 2007 06:47 PM
si0385.
Dec 17, 2005 01:59 PM
DC2LsVtec
Jun 23, 2003 11:52 AM
