Would this be a good combo with ITR cams?
Old Oct 30, 2001 | 10:11 AM
b16awarrior's Avatar
New User
Default Would this be a good combo with ITR cams?
I already have ITR cams and the basic bolt ons, But the car feels slow at low rpms, midrange is great. I heard from someone I should add ITR IM and TB and then use my vtec controller to move the activation point higher. does this sound like a good idea? Right now I upped the fuel pressure from 45psi to 50psi at WOT because I was afraid I was running rich.
Old Oct 30, 2001 | 10:43 AM
bojangs's Avatar
New User
Default Re: Would this be a good combo with ITR cams? (b16awarrior)
you were afriad you were running rich so you made it even richer? hmm..
Old Oct 30, 2001 | 10:46 AM
FAST94GSR's Avatar
New User
Default Re: Would this be a good combo with ITR cams? (bojangs)
Newsflash:
B16's don't make a lot of torque, especially on the low end. If you're afraid you're running rich why'd ya up the fuel press? What are you thinking?
Old Oct 30, 2001 | 11:06 AM
bojangs's Avatar
New User
Default Re: Would this be a good combo with ITR cams? (FAST94GSR)
hahhahaha.. i love how you put it so gently!
Old Oct 30, 2001 | 03:06 PM
New User
No, we believe it was running lean because it was bogging really bad on hot days, after increasing the pressure it runs fine....until nighttime when it starts bogging again.
Old Oct 30, 2001 | 04:29 PM
Padawan's Avatar
Darth ModerVader
You'll probably want to get it on a dyno with a wideband 02 and do some tuning. Chances are that there's a good deal more power in your current setup with the right fuel, vtec x-over, and cam timing settings.
Miguel613ekb18c
Engine Management and Tuning
10
May 16, 2014 05:00 PM
Listerofsmeg
Jan 7, 2012 07:50 PM
Will_H
Jul 7, 2009 04:54 AM
ITR607
10
Dec 8, 2002 10:21 PM
ZERO COOL
Feb 10, 2002 02:01 PM
