Quick Question : Hubcentric Rings, do I need them?
Old Oct 30, 2001 | 10:06 AM
Seann's Avatar
Default Quick Question : Hubcentric Rings, do I need them?
Installing my new rotas right now and i need to know if I need to put the hubcentric ring from my old wheels on when i mount these new wheels. The Rotas did not come with them..
Thanks!
Old Oct 30, 2001 | 10:09 AM
sackdz's Avatar
Default Re: Quick Question : Hubcentric Rings, do I need them? (JediGSR)
Let me know how it turns out, i'll be in the same spot soon.
Old Oct 30, 2001 | 10:12 AM
Warren's Avatar
Wrong-Way Wang
If they did not come with them, then they probably don't need them, but you do need to make sure that it's fitting around the hub. Bolts do not hold the wheel in place. The hub does that. Bolts are to hold the wheel against the hub. If the wheel isn't hubcentric, you could get all sorts of problems.
Warren
Old Oct 30, 2001 | 10:18 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: Quick Question : Hubcentric Rings, do I need them? (Warren)
As Warren stated, the wheel should be resting on the hub. So when you put the new wheels on, check to see if the wheels fit on the hub. If not, put the rings in and try again. The rings from your old wheels might not fit your new Rotas.
Seann's Avatar
My Kosei hubcentrics wouldnt fit so I'm just going to leave them off I guess. I don't think its going to be a problem.
Old Oct 30, 2001 | 10:53 AM
fangtl's Avatar
Even if it's a problem, it's a problem you'll probably not notice, why don't you spend a few bucks on the rings (they are like 1.50 a piece at Sears, bring the inner and outer diameter) and safe yourself the trouble of worrying
Old Oct 30, 2001 | 11:10 AM
Seann's Avatar
Default Re: Quick Question : Hubcentric Rings, do I need them? (fangtl)
Yeah I'm going to pick some up tonite. Just got them all on. I'm as giddy as a schoolgirl, the slipstreams look so nice. But I love black wheels, I'll have pics in the apperance section tonite if anyone wants to check em out.
Thanks everyone!
Old Oct 30, 2001 | 12:41 PM
tatty's Avatar
New User
You'll actually notice heavy vibration at high speeds if you have improper hubcentric config. Best to get the hub spacers before you put your wheels on.
Old Oct 30, 2001 | 01:47 PM
Seann's Avatar
Default Re: Quick Question : Hubcentric Rings, do I need them? (tsaktuo)
Yeah I think I need to get some, I'm getting some slight shaking between 70-80mph with no rings.
91bluehatch
Jun 15, 2010 05:42 PM
Hawkze_2.3
Jan 17, 2007 12:36 PM
mulletov
Jul 8, 2006 04:14 PM
bee16a
Mar 31, 2003 09:54 AM
grngsr01
Oct 16, 2002 12:37 PM
