jdm GSR ecu VS. usdm GSR ecu
Old Apr 19, 2004 | 04:20 PM
wizzards581's Avatar
Default jdm GSR ecu VS. usdm GSR ecu
are the rev limit different? where does the US cut fuel at and where does the JDM cut fuel at?
which is better to use?
Old Apr 19, 2004 | 05:41 PM
WreckedTeggie's Avatar
Default Re: jdm GSR ecu VS. usdm GSR ecu (wizzards581)
I have a jdm one that came with my swap, at first it wouldnt let me hit vtec (damn knock sensor) but after i got everything figured out it engaged at 4400 rpms which i thought was a little low, anyways the rev limiter (fuel cut u said) is higher, but i dont know wat its at bc i never took it up that high. I did however hit 7300 fuel cutoff on my p28 today..... hmm
Old Apr 19, 2004 | 07:59 PM
Default Re: jdm GSR ecu VS. usdm GSR ecu (WreckedTeggie)
since that jdm gsr puts out 180 hp and usdm puts 170hp, can this be affected by the ecu somehow?
Old Apr 20, 2004 | 04:23 AM
It's also alot smaller in size..
Old Apr 20, 2004 | 12:58 PM
00CIVICSITEIN's Avatar
I'm not sure if this makes sense...but since the jdm ecu is smaller can you still put ubderdata in the socket...like is the socket still there for the additional chip?
Old Apr 20, 2004 | 03:48 PM
mugenracer's Avatar
vtec engagement is the same for both USDM and JDM (4400rpm) as is the secondaries (5800rpm) the JDM p72 redline is at 8200rpm, fuel cutoff is 8300-8400rpm...just after the redline.
Old Apr 21, 2004 | 03:56 PM
Default Re: (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">vtec engagement is the same for both USDM and JDM (4400rpm) as is the secondaries (5800rpm) the JDM p72 redline is at 8200rpm, fuel cutoff is 8300-8400rpm...just after the redline.</TD></TR></TABLE>
i never drove a USDM gsr before, whats the fuel cutoff for US gsr?
darkstar1440
Sep 28, 2006 08:37 PM
AreJay126
Jul 21, 2005 05:25 PM
jeffchaisi
Apr 23, 2005 09:51 AM
wizzards581
Nov 16, 2003 04:20 PM
nathn_ep3
Feb 21, 2003 06:17 PM
