H22 VSS problem can anyone help?
Hey guys as the topic says i have a problem with my vss when i driving i dont know what speed iam going? is this a common problem with H22a? i also have a anoying 5th gear grind thats sucks. anyone?
Either your wiring is bad of the sensor could have came loose. The whole VSS assembly is only held on by one small bolt so if it comes loose for whatever reason and the gear isnt locked in you will not get a reading.. Make that its tight and then make sure wiring is secure..
