HELP! ! Brake lights turns on wen' parking lights is on
Old Apr 18, 2004 | 10:42 PM
supraUGlyy's Avatar
Default HELP! ! Brake lights turns on wen' parking lights is on
tis' is wierd....it jus' recently happen, when i turn on my parking lights or head lights..my brake lights goes ON ! and it stays on until i turn off my lights.....everything else works fine such as signal, interrior lights , headlights and etc....CAN SOMEONE HELP ME??
Old Apr 18, 2004 | 10:50 PM
96 Ls lnTeG's Avatar
Default Re: HELP! ! Brake lights turns on wen' parking lights is on (supraUGlyy)
Brake switch its under the dash above the brake pedal its kinda in a uncomfortable position to get to.... push the switch all the way in, if it does not turn off... its the switch if it still stay on, you got some wiring problem, what year Teg?
If it is the switch.. make sure you get the right one.. Crusie Control / an Non Crusie Control switches are different
Old Apr 18, 2004 | 11:02 PM
supraUGlyy's Avatar
its a 95 LS....tha switch is in perfect working order...and i already check for all the fuses....
Old Apr 18, 2004 | 11:13 PM
alfaaay's Avatar
I'm not sure if it'd be the same problem, but on my '97 Toyota Corolla, this same exact thing was happening. It turned out to be a grounded wire somewhere. I'm not really sure where or how it was traced since I had our family's mechanic look at it. Good luck.
Old Apr 18, 2004 | 11:17 PM
supraUGlyy's Avatar
Default Re: HELP! ! Brake lights turns on wen' parking lights is on (alfaaay)
THX ! !
Old Apr 18, 2004 | 11:35 PM
supraUGlyy's Avatar
Does anyone else hav' any advice for me??
Old Apr 19, 2004 | 06:01 AM
JimBlake's Avatar
Check the bulbs in their sockets. There's 2-filament bulbs, & if the 2 separate nubs on thier base are mashed together, then the taillights can back-feed into the brake light circuit. Or maybe a 1-filament bulb is installed where it should have a 2-filament? Or a bulb is stuck in it's socket backwards?
If not, then look for wires shorted together. If they were shorted to ground, you'd blow fuses. You might have to dismantle your taillight housings for this...
Old Apr 19, 2004 | 09:10 PM
supraUGlyy's Avatar
Default Re: HELP! ! Brake lights turns on wen' parking lights is on (JimBlake)
PROBLEM SOLVE!! THX AGAIN!!
Old Apr 19, 2004 | 09:19 PM
thaiphob's Avatar
Nikon!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supraUGlyy &raquo;</TD></TR><TR><TD CLASS="quote">PROBLEM SOLVE!! THX AGAIN!!</TD></TR></TABLE>
so how did you solve it?
Old Apr 19, 2004 | 09:29 PM
supraUGlyy's Avatar
Default Re: HELP! ! Brake lights turns on wen' parking lights is on (thaiphob)
There's 2-filament bulbs, & if the 2 separate nubs on thier base are mashed together, then the taillights can back-feed into the brake light circuit. Or maybe a 1-filament bulb is installed where it should have a 2-filament? Or a bulb is stuck in it's socket backwards? JimBlake is right ! ! it was tha 2-filament bulb........
chris spies
12
Jan 16, 2013 04:12 PM
eatsleepvtec
May 20, 2012 11:12 PM
delsizzle1
Mar 22, 2012 10:27 PM
Smash03
Lighting
Apr 28, 2010 12:10 PM
