Timing Belt
Old Apr 18, 2004 | 09:14 PM
MattyP's Avatar
Default Timing Belt
I just hit 90K on my 95 GSR...is it time to change the Timing belt ?...What else should i think about replacing ?
Old Apr 18, 2004 | 09:20 PM
Papantonopoulou1's Avatar
Default Re: Timing Belt (MattyP)
I had my done a few weeks ago. Yeah 90 thousand is when you should change the timing belt. Make sure that they check your exhaust from the cat back if it is still stock. And definitly dont take it to a dealer they will rip you off
Old Apr 18, 2004 | 09:26 PM
94gsr4dr's Avatar
Default Re: Timing Belt (Papantonopoulou1)
change the damn thing
Old Apr 18, 2004 | 09:27 PM
MattyP's Avatar
Yea,i was thinking i need to change it soon...about the exhaust,i got a real bad rattle between 3000-3500 only when the engine is warm,i figured it was the heat shields so i took them off,but it still does it....so i guess thats a reason to buy full exhaust
Old Apr 18, 2004 | 09:29 PM
MattyP's Avatar
94gsr4dr...nice to see a someone on here so close to me....
Old Apr 18, 2004 | 09:33 PM
92Integra
Guest
Posts: n/a
Yeah you should change your timing belt, and water pump, even if the water pump isn't even making any noise at all, believe me makes life alot better when you do them at the same time. It will kinda be a pain in the *** to do the timing belt if it is your first time. But if you got a book and a buddy to help will take like 3 hours at the most.
Old Apr 18, 2004 | 09:36 PM
94gsr4dr's Avatar
there is lots of people from frederick on here.
Old Apr 18, 2004 | 09:59 PM
warrenbaity's Avatar
the worst part about that job is unbolting the crankshaft pulley. once you get that undone, the rest is a breeze.
Old Apr 18, 2004 | 10:13 PM
Stripped Honda's Avatar
99-0104
Default Re: (warrenbaity)
change the timing belt, waterpump, 2 cam seals, 1 crank seal, idler bearring, valve cover gasket, gromets, tube seals, 1 gallon of coolant, and the drive belts ..... that is a complete timing belt job
i usually do the spark plugs and the cap and rotor and while i am at it i will change the distributor o-ring sence i will set the timing after that job ...
get a helms and do it yourself dont pay people to do it ....
Old Apr 18, 2004 | 10:23 PM
Two_K Si's Avatar
Default Re: (Stripped Honda)
Check you coolant hoses also to make sure they are still in good shape, or if your flushing your cooling system, you might as well replace them.
Old Apr 19, 2004 | 12:45 PM
MattyP's Avatar
Default Re: (Two_K Si)
Thanks for the advice guys,this forum is great
RandyOo
Dec 26, 2013 02:35 PM
Cooker4418
Nov 3, 2005 11:42 AM
BlackGser
Apr 27, 2005 11:00 AM
MugenHonda
Nov 16, 2002 08:47 AM
animated_life
Oct 22, 2002 09:48 PM
