Tien S-Tech Vs. Eibach Sportline
Old Apr 18, 2004 | 05:42 PM
Dc2 Powered's Avatar
Default Tien S-Tech Vs. Eibach Sportline
anyone dealing with these 2 springs?
which would give a better drop and preformance? my frined has the sportline on his si and its awsome no gap at all i want springs that will lower a stock integra with no gap between the wheel and fender but the fender not overlaping the wheel.
which would you go with?
Old Apr 18, 2004 | 05:51 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Tien S-Tech Vs. Eibach Sportline (Speedin Type R)
tein
Old Apr 18, 2004 | 06:37 PM
are u saying that because its better or because its the hype on here?
will the tien give a drop so that their is no gap between wheel and fender? amd a smooth ride?
Old Apr 18, 2004 | 06:47 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Go with the Sportline, there was a few threads talking about Tein's low end suspension and how it's mostly hype. I know quite a few people pissed off with S-TECHs. Tein makes good suspension kits if you are gonna buy RAs or REs, but those are like 1600 suspensions.
Old Apr 18, 2004 | 06:49 PM
GG-SquadDB's Avatar
Default Re: Tien S-Tech Vs. Eibach Sportline (JDMThoughts)
I agree Tein is really over rated and overpriced just for their entry level products which are good but not worth the cash the upper level stuff is superb but really will do no good unless u are really hardcore Auto Xer and need a hardcore suspension
Old Apr 18, 2004 | 07:10 PM
FlaN.'s Avatar
S-Techs suck IMO. will they be used with stock shocks?
Old Apr 18, 2004 | 07:27 PM
giff74's Avatar
Default Re: (FlaN.)
I hate my Tein springs!!! They totally dumped the front end of the car. My front tires are a good inch into the fender well and the rear fender line is above the tires.
My next move is going to be some GC's with specific spring rates, then I can use any shocks I want.
Old Apr 18, 2004 | 08:44 PM
for a little bit they will be used with stock shocks till i could get some money to get some
Old Apr 18, 2004 | 08:56 PM
dougw101's Avatar
Default Re: (Speedin Type R)
Lowered on sportlines with stock rims.
Old Apr 18, 2004 | 08:57 PM
is ur front fender overlaping ur tire a little or is it because of the lighting of the picture
Old Apr 18, 2004 | 09:10 PM
dougw101's Avatar
Must be lighting ...
Old Apr 18, 2004 | 09:15 PM
mey_xanng's Avatar
You may want to consider
Tein High Tech springs:
Rate: Front- 296 Rear- 257
Drop: Front- 1.7" Rear- .9"
Progressive
Compared to
Tein S-Tech springs:
Rate: Front-335 Rear-274
Drop: Front- 2.5" Rear- 1.7"
Progressive
and
Eibach Sport Line:
Rate: F&R- Front 231 Rear 143
Drop: F&R- 1.7"
Progressive
http://www.team-integra.net/fo...age=1
Old Apr 18, 2004 | 10:14 PM
WhoisDan's Avatar
tein's will slam your car.
Old Apr 18, 2004 | 10:27 PM
xplanetearth420x's Avatar
Default Re: (whoisdan)
tein
Old Apr 19, 2004 | 04:50 AM
ebelp's Avatar
Default Re: (xplanetearth420x)
Sportlines =
They make the rear of the car lower than the front.
Old Apr 19, 2004 | 02:26 PM
BANGBANG's Avatar
Default Re: (ebelp)
yup i agree with him. when i had my sportlines the front look higher than the back. it was a fudged up drop. or maybe the shop here in this ghetto *** city in texas fudged it up. i dont kno..
Old Apr 19, 2004 | 02:45 PM
EMO-anthony's Avatar
Default Re: (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Sportlines =
They make the rear of the car lower than the front. </TD></TR></TABLE>
I had the same problem so i decided to get a full coilover set up.
JIC Magic FLT-A2s
Old Apr 19, 2004 | 04:25 PM
Nexx's Avatar
Default Re: (skunkB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Sportlines =
The front looks higher than the rear NOT because the springs are bad but because of the way the fenders on our cars are made to give the
illusion that they are off. (In all honesty, I think Eibach make some of the best springs and compared to other springs... they don't tend to
sag as time passes).
It's a 1.7" drop all around... plain and simple. I'm sure there are many springs out there with a lower front drop to offset the illusion like
H&Rs and Neuspeed. Go ahead and check...
Old Apr 19, 2004 | 04:31 PM
FlaN.'s Avatar
I think the "S" in Tein S-tech means "style."
Old Apr 19, 2004 | 04:34 PM
Nexx's Avatar
Default Re: (FlaN.)
By the way... who drives around with a 2.5" front drop with bad camber (negative toe)?
Doh! Nevermind... my friend does. =P Damn H&R racing springs! Really you guys, they're not 2.0" drops.. they're more like 2.5"!
Old Apr 19, 2004 | 04:58 PM
toohott4handlin's Avatar
Default Re: (Nexx)
sportlines
Its a good drop, a little bit lower in the front than the back to give it that "raked" look. Its good if you dont want too low of a drop
-steve
luuisss
Suspension & Brakes
12
Jun 12, 2012 07:50 PM
InterludeTypeR
May 22, 2007 02:02 PM
DC5RN
14
Dec 26, 2006 08:45 PM
WILD_WILL
Honda Civic (2006 - 2015)
15
Sep 26, 2006 06:59 AM
