Increasing brake pedal sensitivity?
So i've finally got the teg on the road, and i've noticed the brake pedal has to be pushed almost all the way to the floor to brake. Is there a way to increase the sensitivity of the brake pedal? Not by a ton, but I definitely want to increase it. Another factor I should add is ABS is not functioning as of now. Would this have an effect? TIA!!!!
I bet you still have air in there. Bleed it again, bleed LOTS of fluid thru the back. Whenever I do mine, it seems like the air is all gone, but if I keep going I finally get more bubbles.
How is your ABS 'not functioning'? Is it still installed? I don't really know if those valves are capable of making the brakes mushy, but I think not.
the abs light is on....I know i have to replace the two front sensors (their cut currently), but not sure if that will fix it.
