Honda S2000 Honda S2000
Does japan get the 2.2l engine also?
Old Apr 18, 2004 | 04:46 PM
Two_K Si's Avatar
Default Does japan get the 2.2l engine also?
I know this is dumb, but a simle question. I was wondering if japan got the 2.2l engine first, or are they still using the 2.0? Be gentle
Old Apr 18, 2004 | 04:55 PM
SimbaDogg's Avatar
Default Re: Does japan get the 2.2l engine also? (Two_K Si)
no
Old Apr 18, 2004 | 05:04 PM
Two_K Si's Avatar
Default Re: Does japan get the 2.2l engine also? (SimbaDogg)
so there must be hardly any aftermarket support for the new s200's then?
Old Apr 18, 2004 | 05:06 PM
Civicboy's Avatar
Japan got the F22c the same year we did. Rumor has it that you have a choice of engines, the F20c or the F22c. All intakes and other bolt on items are the same for both motors.
Old Apr 18, 2004 | 05:13 PM
Two_K Si's Avatar
Default Re: Does japan get the 2.2l engine also? (Civicboy)
Really? i did not know that boltons for the f20c where compatible with the new f22c. Thanks
Old Apr 18, 2004 | 09:16 PM
Civicboy's Avatar
As far as I have been told. The exterior of the motor is the same, internals are what changed.
Old Apr 18, 2004 | 11:19 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicboy &raquo;</TD></TR><TR><TD CLASS="quote">Japan got the F22c the same year we did. Rumor has it that you have a choice of engines, the F20c or the F22c. All intakes and other bolt on items are the same for both motors. </TD></TR></TABLE>
who told you that?
Old Apr 19, 2004 | 07:18 AM
Civicboy's Avatar
Default Re: Does japan get the 2.2l engine also? (vapor)
Well that was the rumor over at S2ki.com. A couple pictures of the new style cluster were showing up with a 9k redline.
Old Apr 19, 2004 | 02:18 PM
WRS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicboy &raquo;</TD></TR><TR><TD CLASS="quote">Well that was the rumor over at S2ki.com. A couple pictures of the new style cluster were showing up with a 9k redline. </TD></TR></TABLE>
If you have no clue, then keep your mouth shut. Feast or famine on rumors? Please hold yourself to a higher standard especially here on honda-tech.com.
Old Apr 19, 2004 | 03:10 PM
evil vapor's Avatar
Default Re: Does japan get the 2.2l engine also? (WRS2K)
[I]<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WRS2K &raquo;</TD></TR><TR><TD CLASS="quote">
If you have no clue, then keep your mouth shut. Feast or famine on rumors? Please hold yourself to a higher standard especially here on honda-tech.com.</TD></TR></TABLE>
easy there, have a No need for harsh flaming.
Rumors don't mean anything in this world. Specultion or assumptions really don't mean anything either. They are just that, rumors, speculations and assumptions. Spreading misinformation on the other hand is... Unless it is certain that Japan gets the 2.2L motor, I wouldn't spread misinfo about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicboy &raquo;</TD></TR><TR><TD CLASS="quote">As far as I have been told. The exterior of the motor is the same, internals are what changed.</TD></TR></TABLE>
I've been told a lot of things, being told is one thing, it's something else when you falsely take that info and accept it as truth and spread that. Like the s2000 type R, inline 6 cylinder making 350hp or whatever the hell it was.
Old Apr 19, 2004 | 05:41 PM
Civicboy's Avatar
I realize that rumors are just that, rumors. I am working on getting some more evidence to support my statements as I type this. While I do that here are some of the pictures I was talking about.
USDM cluster
JDM cluster
If they don't get the the choice then they only have the F20c, if I was wrong about being able to choose I will admit that, but I am working on finding out.
Thanks
Old Apr 19, 2004 | 08:33 PM
spirit R
Guest
Posts: n/a
S2000 basic information top&gt;specifications
|to S2000 basic information top|
Leading particular
Type S 2000 S 2000 type V
Transmission 6 fast manuals
Car name type HONDA ABA-AP1
Size
Weight
Riding in a car fixed capacity Total length Â~ full Â~ total height (m) 4.135Â~1.750Â~1.285
Wheel base (m) 2.400
Tread (m) Before 1.470
After 1.510
Roadspace (m) 0.130
Vehicle weight
(Kg) 1,250 1,270
Navigation equipped car 1,260 1,280
Riding in a car fixed capacity (name) 2
Inside passenger compartment
Size (m) Length 0.800
Width 1.350
Height 1.055
Engine Engine type F20C
Engine type number of cylinders and arrangement Water cooling serial 4 cylinder vertical positions
Valve gear DOHC chain & gear drive
Inhalation 2 exhaust 2
Total cubic displacement (cm3) 1,997
Inside diameter Â~ distance (mm) 87.0Â~84.0
Compression ratio 11.7
Fuel feeder type Electrically controlled gasoline injection system
(HONDA PGM-FI)
Use fuel type Unleaded premium gasoline
Fuel tank capacity (L) 50
Lubricating system Force system
Efficiency The highest output
(KW [ PS ] /rpm)* 184 [ 250 ] /8,300
Largest torque
(N m [ kg m ] /rpm)* 218 [ 22.2 ] /7,500
Fuel consumption rate (km/L)
10 15 mode travelling (national traffic economical examination value) 12.0 11.6
Principal fuel economy improvement measure Variable valve timing,
Electromotive power steering
Minimum turning radius (m) 5.4
Power transmission
Running gear Clutch type Dry veneer diaphragm
Transmission type Regular gearing system
Transmission operation system Floor change system
Change gear ratio 1st gear 3.133
2nd gear 2.045
3rd gear 1.481
4th gear 1.161
5 speeds 0.970
6 speeds 0.810
Retreat 2.800
Reduction gear ratio (primary /2 next) 1.160/4.100
Steering device type Rack & pinion system
(Power-steering specification)
Tire Before 215/45R17 87W
After 245/40R17 91W
Steering turning numbers from rock to rock
(Lock two lock) 2.6 1.4
Type type of main brake Before Hydraulic type ventilated disk
After Hydraulic type disk
Suspension system (before/after) ƒ_ƒuƒ‹ÂƒEƒCƒbƒVƒÂcƒ{Â[ƒ“ system
Stabilizer type (before/after) Torsion bar system
This is tranlated specs from Honda of Japan not a rumor they did make 1 change it appears and that was to give the Type V better gearing but it does'nt want to translate sorry
Old Apr 19, 2004 | 11:32 PM
Civicboy's Avatar
Default Re: Does japan get the 2.2l engine also? (Duke Togo)
OK there you have it, I was wrong about Japan having a choice of motors. Japan only has the F20c.
Old Apr 21, 2004 | 12:28 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicboy &raquo;</TD></TR><TR><TD CLASS="quote">OK there you have it, I was wrong about Japan having a choice of motors. Japan only has the F20c. </TD></TR></TABLE>
Old Apr 21, 2004 | 02:05 PM
Civicboy's Avatar
Old Apr 21, 2004 | 02:45 PM
Young_R's Avatar
japan only use the BEST!
Old Apr 22, 2004 | 06:35 PM
Civicboy's Avatar
Default Re: Does japan get the 2.2l engine also? (Young_R)
I agree!
redzcstandardhatch
Jan 17, 2007 02:14 AM
B16b-EJ8
Aug 16, 2006 01:17 PM
Doubledeala
Oct 19, 2004 02:27 PM
khmboostedeh2
May 8, 2004 06:57 PM
invboost
Acura NSX
10
Nov 10, 2003 11:24 AM
