antennae help pls.
Old Apr 18, 2004 | 03:17 PM
alexus's Avatar
Default antennae ?
On my power antennae when it retracts and reaches the bottom I hear a grinding noise. Can someone tell me what it is and how to fix it? Thank in Advance.
Old Apr 18, 2004 | 05:17 PM
John Gordon's Avatar
Default Re: antennae ? (alexus)
what year is your car? mine is a '90, and it does it, worse and worse. at the same time it is not pulling the antenna all the way down, right? I've decided that the plastic gear inside the motor housing is worn and the teeth are skipping. Once the antenna mast flexible shaft starts getting stiff, and its hard to push it into the housing, the teeth just start jumping. you need a new motor and gear. I've seen them on Ebay for $85 used. I expect the dealer cost is much higher.
Old Apr 18, 2004 | 08:20 PM
alexus's Avatar
Default Re: antennae ? (John Gordon)
My honda accord year is 94 and the mast goes all the way down. Maybe its just a matter of time when it won't pull it all the way down. Thanks again
Old Apr 18, 2004 | 08:58 PM
RUBZERK's Avatar
let it go
Old Apr 19, 2004 | 08:48 AM
jfastman's Avatar
Sounds like you just hafta replace the antenna mast assembly. You can get those from the dealer for aroun 50 bucks. It's real easy to replace. Send any questions to jfastman@yahoo.com
Old Apr 19, 2004 | 08:50 AM
jfastman's Avatar
It's not the gear in the motor most of the time. The gears on the antenna mast "tape" are worn. You will want to remove the round cover on the motor/mast assembly to inspect the motor gears. When installing the new antenna mast, cut off the new sleeve that is on the mast. The old sleeve is nearly impossible to remove from the mast base. It will work just fine with the old sleeve still in place. If you have any questions send them to jfastman@yahoo.com
Modified by jfastman at 8:27 AM 4/20/2004
Modified by jfastman at 8:30 AM 4/20/2004
Old Apr 19, 2004 | 07:19 PM
Default Re: antennae ? (jfastman)
Yeah, probably right. He should try that first. On mine, that doesn't fix it any more. I think the motor gear is worn.
Old Apr 19, 2004 | 07:31 PM
Phire's Avatar
you can get entire assembly new from Ebay for $45 shipped. Hirschmann too!
Old Apr 19, 2004 | 07:46 PM
steve-o40's Avatar
my '92 did the exact same thing..they told me i needed a new antennae motor....but instead i just disconected the power to it....so check the motor too..it may be sticking somewhere
Old Apr 20, 2004 | 08:25 PM
Default Re: antennae ? (Phire)
Hey Phire, where on Ebay?
Jlopez08
Honda Insight & CR-Z Hybrid
Apr 15, 2017 01:41 PM
ttcheung97
Sep 14, 2009 05:34 AM
kickflip484
Oct 24, 2006 11:50 AM
bjrta
Aug 6, 2006 08:06 PM
Lude-Conduct
Oct 19, 2003 10:22 AM
