K20 Swap....Questions on Tech..
Old Apr 18, 2004 | 02:26 PM
RatedX's Avatar
Default K20 Swap....Questions on Tech..
We just finished a K20 swap in a 2001 SI(Canada) EX(States). The engine came from a 2003 SIR(canada) SI(US).
It turns over fine but it wont start. We have the SI`s original computer and Key, we even changed the Ignition module that should hold the right code but the car doesnt seem like it wants to recognize the key....
Honda said the key needs to be reprogrammed but they need the serial number of the car which will be hard to get for sure....I already called the company that supplied the parts and they dont seem to know it either...
What to do....
Old Apr 18, 2004 | 02:31 PM
glw's Avatar
glw
Default Re: K20 Swap....Questions on Tech.. (RatedX)
iirc, the key isn't programmed - the ecu is coded to match the key.
i would go back to traditional troubleshooting. no turnover = check for fuel and spark in the cylinders... then check timing...
Old Apr 18, 2004 | 03:05 PM
RatedX's Avatar
Default Re: K20 Swap....Questions on Tech.. (glw)
I am pretty sure the key isnt programed...Honda tells us that we need the serial number of the car to program.....Is there any other way...Engine supplier is dickin us around...
Old Apr 18, 2004 | 03:36 PM
BlueIntegraBoy's Avatar
Can't have someone reflash your ECU taking out the immobilizer function?
Old Apr 18, 2004 | 03:38 PM
RatedX's Avatar
Default Re: K20 Swap....Questions on Tech.. (BlueIntegraBoy)
I dont know....I am trying to find out the answers to these questions....
Old Apr 18, 2004 | 03:42 PM
Big Si Guy's Avatar
All you need is the VIN from the car the ECU came from, then any Honda dealership will be able to flash your ecu to accept the original key, etc. It takes about 5 mins.Your car will not start w/o getting this done. I'm sure there is a way to physically bypass the immobilizer but i dont suggest anyone tell, if they do know how.
Old Apr 18, 2004 | 03:58 PM
RatedX's Avatar
Default Re: K20 Swap....Questions on Tech.. (Big Si Guy)
The problem we are having is getting the VIN # from the donor car....The engine supplier is not very fast or co-operative...
Can we bypass?
Old Apr 18, 2004 | 07:15 PM
Kal's Avatar
Kal
Default Re: K20 Swap....Questions on Tech.. (PIMPASSBEOTCH)
get a k-pro ecu
Old Apr 18, 2004 | 08:28 PM
k20whitevic's Avatar
Try using your civic VIN. When I did mine, Honda told me they used mine (even though I had the rsx-s vin (had an A2 before the A)) and said it worked fine.
Old Apr 19, 2004 | 07:00 AM
RatedX's Avatar
Default Re: (k20whitevic)
We have a Honda tech coming tonight to check it out....any other advice just in case...
BTW...Thanks to everyone that posted so far...
Len
toytroy
Sep 27, 2012 10:06 AM
97preludetypeblk
Aug 13, 2006 07:27 PM
Vtakkk
Mar 26, 2006 02:38 PM
93DA530
Nov 24, 2003 11:10 AM
lude97dude
Jan 21, 2003 08:53 PM
