LS VTEC???
Old Apr 18, 2004 | 12:07 PM
808jdm_gsr's Avatar
Default LS VTEC???
LS/Vtec....is it worth doing...and what do I need to build up for it to really work....
Old Apr 18, 2004 | 12:09 PM
aznballer's Avatar
if u search there should b many topics on this
Old Apr 18, 2004 | 03:15 PM
BoBoChan's Avatar
Default Re: LS VTEC??? (808jdm_gsr)
is ls vtec better then gsr vtec, cause im just hearin bout ls vtec and nothin bout gsr. is there sumthin i dont know. peace.
Old Apr 18, 2004 | 04:58 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: LS VTEC??? (BoBoChan)
gsr vtec???? wowzers kid, you got alot to learn
IMO if you already have a gsr i'd just build that motor
Old Apr 18, 2004 | 05:11 PM
GotGSR's Avatar
Default Re: LS VTEC??? (usdm420)
The gsr motor already has vtec, so "gsr vtec" is like saying "japanese honda". THere's nothing else it could be.
An ls/vtec is when you swap a vtec head (b16, b18c, etc.) onto an LS block, which did not originally come with vtec. Hopefully that clarifies something for you. The ls/vtec tends to yeild more power due to a higher compression ratio. The question of whether its better or not is very debatable.
Modified by GotGSR at 6:22 PM 4/18/2004
Old Apr 19, 2004 | 01:50 PM
808jdm_gsr's Avatar
Ok so this is what I need right....
complete VTEC head, complete intake manifold, intake manifold gasket, head gasket, oil lines, dowel pins, head studs, GSR water pump, timing belt, balanced crank, higher compression pistons, wrist pins, pistons rings, main bearings, rod bearings, front main seal, rear main seal and exhaust manifold gasket
So I was wondering what kind of parts different people used...and which one most people use on Ls/vtec....
Old Apr 19, 2004 | 02:16 PM
redlinetuning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808jdm_gsr &raquo;</TD></TR><TR><TD CLASS="quote">Ok so this is what I need right....
So I was wondering what kind of parts different people used...and which one most people use on Ls/vtec....</TD></TR></TABLE>
well.. you can certainly reuse your dowel pins.. you just have to relocate them to the other side of the head/block. secondly, you can use the stock ls rods/pistons if you're on a tight budget, but if you have some to spare, might as well while you have everything dissassembled. pm me if you have questions.
Old Apr 19, 2004 | 02:44 PM
xplanetearth420x's Avatar
Default Re: LS VTEC??? (redlinetuning)
yes ls/vtec is worth it im not going to sit here and tell you everything you have to do but i saw a thread about it not to long about try a search
Old Apr 19, 2004 | 02:45 PM
integraGSR1's Avatar
yes, do a search! i don't think it's worth in IMO
Old Apr 19, 2004 | 02:48 PM
EMO-anthony's Avatar
Default Re: (integraGSR1)
People think its easy to do LS/VTEC but its not. You have to make sure its DONE RIGHT. This subject has been discussed too many times SEARCH you'll find many articles pertaining to this subject.
Old Apr 26, 2004 | 11:18 AM
BoBoChan's Avatar
wuts compression.. ratio. i know the numbers are like 11:5:1 or sumthin but i never knew what those meant.
Old Apr 26, 2004 | 01:34 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
ok so it either the b16 head or the b18c head .....if soo which is better?
Old Apr 26, 2004 | 01:49 PM
usdm420's Avatar
Community Builder
Default Re: LS VTEC??? (TeGmAn18)
try searching for that one too, its been beat to death
Old Apr 26, 2004 | 02:12 PM
UnionCity LS's Avatar
dam n00b convention haha
Old Apr 26, 2004 | 11:02 PM
99sonicbluegsr's Avatar
most prefer the GSR head because of the shorter deck hieght, thus higher compression
Old Apr 26, 2004 | 11:14 PM
Sack Master's Avatar
Default Re: LS VTEC??? (99sonicbluegsr)
You forgot vtec oil pump. If you are doing an LSVTEC its a very good idea to put at least new pistons, and rod bolts in it. You will gain a considerable amout of horsepower with b16 pistons over ls. Its definitely cheaper to do an lsvtec over a gsr. But I prefer gsr more. I'm just glad I'm finally going to take my lsvtec out of my teg and put my gsr back in it. It's almost finished, I miss my baby. I've had the lsvtec in there for 3 years and no major problems except once I busted an oil line doing about 100mph. Scared the crap out of me. Smoke everywhere. Luckily I only lost about 1/2 a quart is was just nicely spraying directly onto my cat .
But to answer your question if you have an otherwise stock LS engine and you want more power. In my mind its definitely a good idea.
adamintegra06
Nov 19, 2008 05:32 PM
CR3X
Oct 26, 2007 05:43 PM
CivicK20
Oct 29, 2006 01:47 PM
92B18Bvx
18
Apr 5, 2004 08:28 PM
integ_newbie
Aug 6, 2001 08:54 AM
