Tire air pressure
Old Apr 18, 2004 | 12:37 AM
ylen13's Avatar
Default Tire air pressure
I have seven generation Honda acccord lx 2003. On the driver side door its says for the front time to use 30psi and for the back 29psi. Should i follow honda recommendation or should i use 35psi for front and back tires?
thanks for any replys in advance
Old Apr 18, 2004 | 12:55 AM
D16Z6racing's Avatar
Default Re: Tire air pressure (ylen13)
I'd read what the PSI says on the tire, not the door. Thats me though. That 30/29 does sound pretty low.
I'm running 34psi (92 Accord). When I have 16's a nd lo-pro tires I ran 39psi.
Old Apr 18, 2004 | 03:42 AM
TypeSH's Avatar
Default Re: Tire air pressure (D16Z6racing)
if you have the factory tire size on it, you should stick to what honda recommends. I generally go 2-3 psi higher than the recommended though. It gives me a leeway period when air runs out and I'm still in the safe range w/o having to check the air too often. Usually check them every 2 months or so.
And the pressure is always measured cold. I found out once theres a 7-8psi difference when the tires are warm/hot (and the outside temp is warm) than when they are cold. 37psi turned out to be an under-inflated 29-30psi (32psi recommended for me)
Old Apr 18, 2004 | 05:19 AM
Mike813's Avatar
Default Re: Tire air pressure (TypeSH)
yep.. most tires recommend 32-34 psi... better safe than sorry.
Old Apr 18, 2004 | 06:43 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ylen13 &raquo;</TD></TR><TR><TD CLASS="quote"> On the driver side door its says for the front time to use 30psi and for the back 29psi. Should i follow honda recommendation or should i use 35psi for front and back tires?
Those number are Hondas reccomendations for the best mix of ride quality, tire wear and performance. Feel free to adjust them to your driving style/needs/wants.
Old Apr 18, 2004 | 06:45 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing &raquo;</TD></TR><TR><TD CLASS="quote">I'd read what the PSI says on the tire, not the door. </TD></TR></TABLE>
The only lising on the tire is manufacturers max allowable air presure. It's not a good idea to go higher.
Old Apr 18, 2004 | 10:23 AM
ylen13's Avatar
thanks everyone for reply it helped allot
nizakia
Jan 21, 2009 02:22 PM
Ash81
Sep 19, 2006 10:43 PM
TL168
Mar 21, 2004 03:19 PM
ahunt01
Jul 17, 2003 04:22 PM
JoshuaVTEC
11
Jul 8, 2003 01:06 AM
