Blowing smoke
Old Apr 17, 2004 | 04:11 PM
Layziebtnh055's Avatar
Default Blowing smoke
my car is blowing alot of smoke, its weird because if i hold down the gas at at around 4-5k it wont smoke until i let off the gas???? any ideas??? i think its bad valve seals im not sure
Old Apr 17, 2004 | 04:50 PM
Riceburner247's Avatar
Default Re: Blowing smoke (Layziebtnh055)
What color smoke?
Black - Motor running rich
Blue - Oil leaking into cumbustion chamber, usually from worn piston rings.
White - Coolant leaking into cumbustion chamber, usually from blown head gasket.
Old Apr 18, 2004 | 12:38 AM
LisaCivic's Avatar
Default Re: Blowing smoke (riceburner247)
with blue smoke is there any way to temperary fix it with out doing alot of work, i am getting a new engine soon but just car smoking buggs me
Old Apr 18, 2004 | 09:41 AM
CptMidway's Avatar
Default Re: Blowing smoke (LisaCivic)
Go down to your local parts store and see if they have any oil additives that will prevent oil burning. Like Barhdal's No-Smoke, or something like that.
HTH
Old Apr 18, 2004 | 10:02 AM
ijjz's Avatar
Would this smoking you are talking about happen after you did a mpfi swap? Just asking since you asked about the throttle cable.
Old Apr 18, 2004 | 10:06 AM
spaceman's Avatar
Default Re: Blowing smoke (CptMidway)
ya that oil additive called restore works good
Old Apr 18, 2004 | 10:40 AM
Ravage70's Avatar
Default Re: Blowing smoke (spaceman)
are u running a turbo or are u stock
and is it burning oil all the time or only when u shift
Old Apr 18, 2004 | 10:41 AM
Ravage70's Avatar
Default Re: Blowing smoke (Ravage70)
if it is wqhen u let off the gas then it is the vlave seals
those are pretty easy to change compared to rings
Old Apr 18, 2004 | 11:45 AM
Ravage70's Avatar
go to ur honda dealer and buy all the intake and exhaust vlave stem seals
u also need to rent the spring compressor tool
go here http://www.homemadeturbo.com/f...10912 and download the civic manual
tells u exactly how to change the seals
sry about not replying the im, im still a trial user
honshu
Jun 9, 2012 10:36 AM
callmechad
12
Feb 9, 2009 01:36 PM
B18cFreak
Apr 17, 2007 02:04 PM
Lucky-13
Jan 31, 2007 05:21 PM
wullie_vtec
Apr 5, 2006 06:07 PM
