smoking issue.
smoking issue.
ok i have a 95 Honda Civc. and im smoking pretty bad. when i gve it some gas i smoke toooo much.
iv had my oil changed many times and done the lukas oil treatment. i dont know what it is. could anyone tell me something to help my issue?
Re: smoking issue.
Start with basics, Car, Motor, Anything done recently?
Three big options though why you would smoke (depends on color)
White smoke - Headgasket (coolant getting in combustion chamber)
Blue smoke - Piston rings or valve seals (oil getting in combustion chamber)
Black smoke - Running WAY too rich (too much gas in combustion chamber)
Re: smoking issue.
anyone out there can tell me what i could try to fix things?
process of elimination is what im looking for if its the best i can go
Re: smoking issue.
but if it is purely black smoke you may have disconnected your IAT sensor when you put the CAI on..... if you did it may be tricking the computer about the actual temp of the air entering your engine so it is throwing more fuel than needed.....
If it reads 0 degrees it will throw more fuel into the combustion chamber than if it is reading lets say 110 degrees....(i had a similar problem with my 91 accord) example: cold air is more dense, means it needs more fuel to achieve the proper burn.
kev
Re: smoking issue.
wow thanks for the post about the iat, i have that exact problem. My iat connection is really bad. I knew something was wrong cause i have really dark exhaust, and my plugs got fouled from bein way too rich. When i pull the cel i get a 10 which is iat, so i tested continuity and had none then i sprayed electronic cleaner into the plug and it was perfect continuity so i put it back on and didn't get the code then ten minutes later i got the code. Obviously the plug is bad, can that be taken apart very easily and fixed or should i just get a good plug and solder it in. I don't want to just tear open my plug before i get some good advice, and i wasn't really sure up until now that that was the problem, I was thinking along the lines of headgasket etc.
Re: smoking issue.
hmmm you could probly get a connector off of a wireing harness.... then solder it in.... but a bad head gasket normally dosnt produce dark black smoke..... but if you have fouled out plugs then you may not be burning your air fuel mixture completely..... but fix your IAT connector before you condem your headgasket
kev
Re: smoking issue.
ok sorry for the noob answers. im fairly new to cars and im wanting to learn which is why im here. im pretty much wanting to save money and fix everything myself.
when you said. i need to replace my rings. when you says rings what do you mean?
and about my CAI. i have a little black tube i have thats right above my distributer cap and spark plug wires ( on the left ) i have it in a hole on my CAI. idk if that may be to any help to you. and were abouts do i look for my IAT sensor?
Teamdiesel
12
04-25-2006 06:21 AM
