13b DSM Turbo
Old Apr 17, 2004 | 01:26 PM
H.crx-si
Guest
Posts: n/a
Default 13b DSM Turbo
Its a turbo from a awd 1st gen eclipse w/ automatic trans., is it compatible just like t25 on a crx?????
Old Apr 17, 2004 | 02:17 PM
jedubz's Avatar
Default Re: 13b DSM Turbo (H.crx-si)
There is no such thing as a turbo being compatible with an NA car. It's not like there is a spot it just slides into. You have to make it compatible. But yes it's *been done* if that's what you really want to know.
Old Apr 17, 2004 | 03:29 PM
TiggsCRX's Avatar
http://www.homemadeturbo.com
Old Apr 17, 2004 | 05:34 PM
H.crx-si
Guest
Posts: n/a
I already know the about that link and that it will work with fabrication or proper adapter plates I guess I should be more specific I wanna know if it will fit ok on a hf manifold and if it's similar to the 14b their must be some differences.
Old Apr 17, 2004 | 05:38 PM
crxirex's Avatar
There is a reason for this page below
https://honda-tech.com/zeroforum?id=16
Old Apr 17, 2004 | 06:49 PM
H.crx-si
Guest
Posts: n/a
Wow thanks for the advice your sooooooo clever why dont you be more original and post the search feature as well . I wanted to speak to someone who might have installed this turbo on their crx and how well it spools ect. on a si engine so the crx forum would be a good place to ask dont you think.
Old Apr 17, 2004 | 07:28 PM
crxirex's Avatar
Default Re: (H.crx-si)
Question 1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si &raquo;</TD></TR><TR><TD CLASS="quote"> I guess I should be more specific I wanna know if it will fit ok on a hf manifold and if it's similar to the 14b their must be some differences.</TD></TR></TABLE>
Totaly, different question?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to speak to someone who might have installed this turbo on their crx and how well it spools ect. on a si engine so the crx forum would be a good place to ask dont you think.</TD></TR></TABLE>
I belive you asked, 2 qustion not one, and the first thing you asked had nothing to do with the turbo being used on a SI Motor. Maybe you should think before you speak. I suggested you go there. You "DID NOT" in anyways suggest that you were doing this project on a SI motor, nor anything clairifing that. Hey thanks for your 2 cents though. If you wern't such a noober I might actually give you some advice, but you obviously take tips, and advice the wrong way. There is no need to be a *****, but thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.crx-si &raquo;</TD></TR><TR><TD CLASS="quote">Wow thanks for the advice your sooooooo clever why dont you be more original and post the search feature as well .</TD></TR></TABLE>
Old Apr 17, 2004 | 08:35 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
14B is better than a T25, but not better than a T28, although Road/Race Engineering makes T25s with T28 wheels. You can't retain your HF manifold if that is what you are trying to say, you need to get a whole new turbo manifold made.
Old Apr 18, 2004 | 07:15 AM
H.crx-si
Guest
Posts: n/a
JDMthoughts thanks for some actual help. crxirex your calling me a noob? could you be more stupid I have almost 3 times the posts you have maybe you should be the one thinking before you speak.
Old Apr 18, 2004 | 09:53 AM
crxirex's Avatar
Default Re:
Your post do not mean your smart . Lets not forget it is a computer .
Old Apr 18, 2004 | 10:56 AM
SlowSpoolin1.6SOHC's Avatar
Default Re: Re: (crxirex)
I'm running a 13b on my D16a6, the IC piping is a pain in the *** but it works. And you have to move the wastegate to get it to clear the tranny mount.
Modified by SlowSpoolin1.6SOHC at 12:12 PM 4/18/2004
standbackimapro
Aug 6, 2006 08:02 PM
illogic65
Aug 24, 2004 06:18 PM
H.crx-si
May 4, 2004 07:12 AM
Type-X
13
Feb 7, 2004 11:34 PM
del_sol
Oct 31, 2002 09:50 AM
