missing or no power through driving range on B18c1
Old Apr 17, 2004 | 11:25 AM
nitelifegod's Avatar
Default missing or no power through driving range on B18c1
i have a 1994 ej1 with a 99 gsr swap B18c1 its been running awesome for like a year but last week the car started losing power on acceleration, it iddles perfect, no cel codes, and i just did a tune up when it misses my exhaust sounds like the car has no spark or fuel( i think it is the coil)
thanks guys(anyone had this problem b4)
any help would be appreciated thanks.
Old Apr 17, 2004 | 12:19 PM
RTE117's Avatar
Default Re: missing or no power through driving range on B18c1 (nitelifegod)
Process of elimination. How old is the fuel filter? What PSI is your fuel pressure set at? Are the plugs/wires/coil old?
Old Apr 17, 2004 | 12:26 PM
Default Re: missing or no power through driving range on B18c1 (IDriveAHonda)
i havent change the fuel filter in like a year,ok the fuel psi is at 40-45 psi
new wires(magnecors),new plugs, now i noticed my dizzy o-ring is leaking oil, also i have a p72 with a skunk2 manifold wannabe(lol, i cut a gsr mani in half and welded a type R mani to it)perfect fit. would the p72 make a loss of power or after i fix this get a new computer?
Old Apr 17, 2004 | 12:28 PM
RTE117's Avatar
I have my P72 w/ Skunk2 IM, never bothered it. Does it backfire when it starts losing power?
Old Apr 17, 2004 | 12:32 PM
yes, big time( i have a greddy PE) i'm a little **** off, and also thanks for answering
Old Apr 17, 2004 | 12:37 PM
RTE117's Avatar
Pull the plugs and check em out, then wires, cap/coil. Do you have an FPR & fuel pressure gauge or is it stock? Get that leak fixed BTW.
Old Apr 17, 2004 | 12:59 PM
u know what it is leaking a little from the gauge, did u use teflon tape?ooon it(i'm an idiot)
Old Apr 17, 2004 | 01:32 PM
RTE117's Avatar
I didn't at first, then my car would cut out every once in a while, I took it out, put teflon on the threads and applied silicon to the copper washer. Works fine now.
Old Apr 17, 2004 | 01:38 PM
i'm going to do that, i hope thats the problem, thanks dude i really apppreciated
Old Apr 17, 2004 | 01:47 PM
RTE117's Avatar
Also make sure your fuel pressure is adequate. This was part of my problem as well. 38 PSI is stock, but mine doesn't like below 46 PSI now.
Old Apr 17, 2004 | 03:17 PM
i just checked mine is at 40 psi is that low( i have DC header,akimoto intake,greddy PE exhaust, and p72 also act stage 2 and old school spoon flywheel) my next mod is going to be a better header and also intake then some headwork i'm staying all motor
Old Apr 17, 2004 | 03:21 PM
RTE117's Avatar
Like I said with mine, I feel bog below 46 PSI. I have a Walbro 255 and B&M FPR. I have it at 52 right now and it feels good, even with spray.
Old Apr 17, 2004 | 03:55 PM
mine is bogging still, but is not leaking from there anymore( i also got a new fuel filter) so thats eliminated it only does IT when the car is already warm up. any new ideas
Old Apr 17, 2004 | 04:04 PM
RTE117's Avatar
Is the fuel pressure still at 40?
Old Apr 17, 2004 | 04:23 PM
yeah at 40 psi, i dont have a FPR yet i'm buying one on monday
Old Apr 17, 2004 | 04:29 PM
RTE117's Avatar
How do the spark plugs look?
Old Apr 17, 2004 | 04:40 PM
2lua's Avatar
check your injectors, and fuel pump. sounded like your car didn't get enuff fuels.
Old Apr 17, 2004 | 04:55 PM
Default Re: (2lua)
how can i check my fuel pump?
i will check the spark plugs tomorrow.
it look like i'm not getting fuel or spark but i think is fuel
RTE117's Avatar
Default Re: (nitelifegod)
Is the fuel pump stock? I can tell with mine, she whines like a **** when I prime it. Walbro love
Old Apr 18, 2004 | 04:16 AM
Default Re: (IDriveAHonda)
i think the pump is stock(when i got the car it had a d16z6 on spray) i took out the nitrous(it had a direct port on a sohc) but never check the pump.
Old Apr 18, 2004 | 08:55 AM
where can i get a good cheap fuel pump for my civic?
i'm staying NA all motor, thanks
Old Apr 18, 2004 | 01:21 PM
TTT bump
preludesarefun
May 1, 2012 03:18 PM
fsg231
Aug 25, 2009 06:05 PM
jawsiiv
Aug 16, 2008 12:26 PM
totsie7944
Dec 8, 2006 10:10 AM
SiCkSrV
Mar 18, 2003 07:37 PM
