99 honda accord won't start.
i drove it all last night and it seem ok nuttin wrong but wen i parked it outside last night and i tried to start it today it won't start .the radio and everything turned on but not the engine.do u guys think it's the starter? i heard a click noise everytime i tried to start it.TIA
usually the clicking noise means the battery because there just isnt enough power to get that starter to try to crank over that engine. def check the ba
ttery
ttery
yo i had this problem. first off do u have an alarm installed? if u do, the "technitian" might of screwed up. u can also check ur battery connections for corrosion ( if there is, clean it off and sand it down for max connection)also have it check at ur local parts dealer for free, also check ur ignition switch which is down by ur fuse box or steering column, then finally yes that lil bastard starter. but first check if it is ground of right but u should remove it and have that checked too
