How hard is it to remove a crossmember ??
Old Apr 16, 2004 | 11:11 PM
187ROCK's Avatar
Default How hard is it to remove a crossmember ??
i bent mine pretty bad ... so now how hard is it to replace it myself ?? is it all bolts and stuff or is welding and cutting involved ??
Old Apr 16, 2004 | 11:14 PM
del_parker's Avatar
Default Re: How hard is it to remove a crossmember ?? (187ROCK)
all bolts.
Old Apr 16, 2004 | 11:17 PM
@ries's Avatar
yup... all bolts, nuts, and some screws. No cutting/welding necessary.
Old Apr 17, 2004 | 04:36 AM
187ROCK's Avatar
Default Re: How hard is it to remove a crossmember ?? (@ries)
thanks alot guys
Old Apr 17, 2004 | 04:34 PM
OTT's Avatar
OTT
https://honda-tech.com/zerothread?id=712816
this might help you, i did the same. Which bits have you bent? i damaged the lower control arm mount on the rear cross member so I just replaced everything
Old Apr 30, 2004 | 10:28 AM
slofu's Avatar
where the hell are my side vents for which i paid you weeks ago?
Old Apr 30, 2004 | 10:39 AM
ITAcelica's Avatar
Me and My friend did it last year at buttion willow race way. It was during HC, he took the off road track hehehe. It took us less then 2 houres to remove the crossmember and left side axil.
cehcivic15
14
Jun 18, 2012 12:50 PM
type Gendy
17
Jan 4, 2008 08:14 AM
superman3503
Suspension & Brakes
May 25, 2006 08:15 PM
kendon
Feb 11, 2004 03:42 PM
