k20 weight?
Old Apr 16, 2004 | 10:59 PM
JDMlyfestyle's Avatar
Default k20 weight?
I did a search and all i found was weight debates for b and h series. Does anyone know how much a k20 weighs compared to a B series? thanks
Old Apr 16, 2004 | 11:03 PM
99blackcivicSi's Avatar
Default Re: k20 weight? (JDMlifestyle)
Roughly the same a B16
Old Apr 16, 2004 | 11:39 PM
ej1 pilot's Avatar
i head k20 was a little lighter than most b series
EDIT- also the block is closer to the passanger side so it distributes wieght in the front- better for hanfling
Old Apr 17, 2004 | 01:51 AM
Dveloped's Avatar
Default Re: k20 weight? (CXinthemaking)
k20 is about 30-40lbs lighter than a b-series
Old Apr 17, 2004 | 02:05 AM
handa's Avatar
Default Re: k20 weight? (Dveloped)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dveloped &raquo;</TD></TR><TR><TD CLASS="quote">k20 is about 30-40lbs lighter than a b-series</TD></TR></TABLE>
i never knew that. something learned today.
Old Apr 17, 2004 | 02:06 AM
ijjz's Avatar
Default Re: k20 weight? (handa)
I believe the tranny is smaller too, from what I've read.
Old Apr 17, 2004 | 05:29 PM
Dveloped's Avatar
Default Re: k20 weight? (ijjz)
tranny is smaller and lighter
Old Apr 17, 2004 | 05:39 PM
B18C5-EH2's Avatar
Former Moderator
Loved
K20a swap is supposed to be about 20lbs. lighter than a B18C5 swap.
Also something interesting:
The TS-X has a magnesium tranny case which is light as hell!
If the issue is H22A weight vs. K20A weight - it's not contest.
Old Apr 17, 2004 | 06:07 PM
brian g's Avatar
Approximately the same as a B16A, engine trans and axles.
brian g
Old Oct 6, 2004 | 06:25 PM
Cyphear's Avatar
B-Series engine/trans: 401 pounds
K-Series engine/trans: 403 pounds
(https://honda-tech.com/zerothread?id=879297)
EDIT: Sorry for bringing this post back from the dead!!!! i was searching around. whoops!!
Old Oct 6, 2004 | 09:23 PM
fabworxs's Avatar
Default Re: k20 weight? (Cyphear)
Yeap...if you read thru honda tunning it says k is lighter than b
Old Feb 14, 2005 | 09:06 AM
90 Si Hatch's Avatar
Default Re: k20 weight? (fabworxs)
My buddy just put a K20 in his 95 GSR he bought the car as a theft recovery, when installed, it sitts soooo much higher in the front. it looks like a fkn monster truck. i know that the tranny has to be heavier than a b series, simply b/c of the 6th gear. but everything else on the motor is alluminum(brackets and such) but overall the k is alot lighter than the b
Old Feb 14, 2005 | 10:03 PM
zz10xx's Avatar
Default Re: k20 weight? (White90SiHatch)
the k20a 6 speed tranny is smaller and lighter(semi dry sump) than b18c type R tranny
burnoutdoc
Apr 24, 2007 06:02 AM
kawgomoo
Apr 7, 2006 08:54 PM
H2nr
Feb 20, 2006 06:44 PM
day1si
Aug 20, 2003 07:59 AM
Eg6_JDM
Mar 21, 2002 05:20 PM
