T70 turbo kit for b16
im seriously thinking about getting a t70 turbo set up for my b16 in my crx.. the kit comes with the manifold wastegate turbo.. wat else will i have to do to complete the install is putting a t70 on a b16a safe to do?... how much horsepower should i be pushin
yeah, for a turbo that size u will need a well upgraded fuel system, some sort of programmable enginemanagement
that turbo is pretty huge, better hope its ball bearing, because u gonna take a while to spool up, you might even need some nitrous to help the spooling, a good sized t3/t04 should do the job, or even SCXX turbo, depending on how u size them, those turbos are good up to about 600hp, i dought you want more than that, unless u are aiming to run high 9s
Well, let me put it this way: My buddy with a built, stroked, 2.0 liter GSR engine (aiming for low 10's) is going to be running a T70. Is your b16A basically stock? If so, then that turbo is wayyyy overkill.
