Just changed my brake pads, but I have a question
Old Apr 16, 2004 | 03:16 PM
SoCal ITR's Avatar
Default Just changed my brake pads, but I have a question
I didn't seem to have a shim or whatever it is on the front pads, I only had them on the rears... is this a problem? Thanks.
Old Apr 16, 2004 | 03:49 PM
mikehonda's Avatar
Default Re: Just changed my brake pads, but I have a question (SoCal ITR)
No, not a saftey issue. Could and prolly will get noisey tho.
Old Apr 16, 2004 | 04:54 PM
davidnyc's Avatar
I haven't used shims in a very long time. My brakes have not been noisy. So, it may not be that much of a big deal. May also depend on what manufacturer of brake pad.
Old Apr 16, 2004 | 05:12 PM
98itR484's Avatar
Default Re: Just changed my brake pads, but I have a question (davidnyc)
you're going to have to take it all apart again, go find some shims and re do everything, no shims is no good!!!!
Just giving you a hard time chris, it shouldnt be a problem, I havnt ran shims in a long time as well
-Arno
Old Apr 16, 2004 | 05:27 PM
DutchITR1689's Avatar
Actually, why is it less noisy with those shims? Does anyone know how it works?
Sukebei Oni's Avatar
Default Re: Just changed my brake pads, but I have a question (98itR484)
unless the pads are OEM honda, i don't run shims, they always end up sliding out a little and cause grinding noises. as long as you greased up the back of the pad, it should be fine.
Old Apr 16, 2004 | 11:30 PM
DC2*Integra's Avatar
Default Re: Just changed my brake pads, but I have a question (Sukebei Oni)
i dont even greese up the back of the pads. will that cause any problems?
Old Apr 16, 2004 | 11:46 PM
dk127's Avatar
Default Re: Just changed my brake pads, but I have a question (DC2*Integra)
jeez they give you the grease, might as well use it?!
Old Apr 16, 2004 | 11:49 PM
Default Re: Just changed my brake pads, but I have a question (dk127)
i didnt get any with hawk pads from pep boys
Old Apr 17, 2004 | 12:28 AM
jonas's Avatar
its to reduce noise in the brakes... you'll be fine without the "grease"
Old Apr 17, 2004 | 12:32 AM
SoCal ITR's Avatar
Default Re: (jonas)
No grease, no shims, so far so good.
Old Apr 17, 2004 | 04:11 AM
.RJ's Avatar
.RJ
Default Re: (SoCal ITR)
What are grease and shims?
I never see those in the carbotech box
SkaiWu
Dec 6, 2008 05:12 PM
HonDA INTEGRATY
Dec 5, 2008 07:22 AM
ndogg810
Honda Civic (2001 - 2005)
Jan 6, 2007 05:23 PM
lude1888
Jul 3, 2006 08:59 AM
5-SpeedFreak
Sep 9, 2002 08:12 AM
