Im running rich what should I do?
Old Apr 16, 2004 | 10:09 AM
N hatch's Avatar
Default Im running rich what should I do?
I have a completely stock B18c1 with a P72 ecu/ cat back exhaust/walbro 190 fuel pump "low pressure pump" (no fpr). I think the fuel pump is whats throwing my air/fuel off. I bidded on a B18b fuel pump on ebay. Do you guy's think that should work fine or should I get a GSR pump? Aren't they the same?
Modified by SomeFool at 7:20 PM 4/16/2004
Old Apr 16, 2004 | 10:21 AM
2lua's Avatar
Default Re: Im running rich what should I do? (SomeFool)
how do you know your car is running rich? your walbro fuel pump is good enuff for your gsr motor. if you are using the af gauge to check if your car running rich/lean then you can forget it.
Old Apr 16, 2004 | 10:32 AM
N hatch's Avatar
Default Re: Im running rich what should I do? (2lua)
Well, there is black **** in my exhaust pipe and it gets on my bumper sometimes. Also the exhaust kinda smells like gasoline. Plus people say that black smoke comes out of my exhaust when I mash it. And I get little popping noises when I'm down shifting sometimes. ( I know its not running extremely rich but it does bother me) Oh yeah- I have to get smogged pretty soon too.
Old Apr 16, 2004 | 10:45 AM
Slammd Sol's Avatar
Check your timing
Old Apr 16, 2004 | 10:46 AM
14eight's Avatar
better off running rich then running lean. Get Hondata thats my advice
2lua's Avatar
do a full tune up on it. you probably need a fpr, check your injectors, and run some injector cleaner thru it. for the black smoke your could be burning oils too.
Old Apr 16, 2004 | 10:54 AM
transmission11's Avatar
doesnt oil usualy burn white smoke?
Old Apr 16, 2004 | 10:57 AM
2lua's Avatar
Default Re: Im running rich what should I do? (transmission11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by transmission11 &raquo;</TD></TR><TR><TD CLASS="quote">doesnt oil usualy burn white smoke?</TD></TR></TABLE>
white smoke = burnning coolant = head gasket.
Old Apr 16, 2004 | 11:02 AM
sounds good to me.
Mrfirefox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">check your injectors, and run some injector cleaner thru it. </TD></TR></TABLE>
Yeah do that, If it's still too rich get a tune up
N hatch's Avatar
Aright cool, Thanks. I pretty much have brand new plugs/wires/ cap/rotor/fuel filter and I got oil flushed back to regular oil (lessing burning). I know I probably need a valve adjustment/ timing check and a fpr. But since Im planning to leave my motor stock, I'm getting a B18b fuel pump instead of a fpr (less expensive/ hassle). But now my question is will the LS fuel pump perform the same as a GSR fuel pump. It should be what 135 lph?
Old Apr 16, 2004 | 11:04 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">white smoke = burnning coolant = head gasket.</TD></TR></TABLE>
not always true about the HG. other things can cause it.
white is coolant
blue is oil
black is gas
and so what if you are running rich? better rich than lean. leave it alone.
also, what do you mean no FPR?
Old Apr 16, 2004 | 11:08 AM
eghatchproject's Avatar
Default Re: Im running rich what should I do? (Slammd Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol &raquo;</TD></TR><TR><TD CLASS="quote">Check your timing</TD></TR></TABLE>
Are you talking ignition timing or cam timing?
I bought an Aeromotive FPR and B&M guage for my LS swap cause I think I am running rich too. I haven't installed them yet but I'll let ya know what I find out.
2lua's Avatar
Default Re: Im running rich what should I do? (Kamin)
fpr= fuel pressure regulator.
Old Apr 16, 2004 | 11:12 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">fpr= fuel pressure regulator. </TD></TR></TABLE>
christ..i know what a FPR...
he said this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">"low pressure pump" (no fpr)</TD></TR></TABLE>
im asking what he means by that, using the stock one?
aw1234dude's Avatar
The ls or b18b pump is 79lph and the gsr pumps are 127lph. I dont believe the 79lph pump will be enough for the gsr motor. I say just stick with your walbro and get it a tune up.
Old Apr 16, 2004 | 11:25 AM
N hatch's Avatar
Default Re: Im running rich what should I do? (aw1234dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aw1234dude &raquo;</TD></TR><TR><TD CLASS="quote">The ls or b18b pump is 79lph and the gsr pumps are 127lph. I dont believe the 79lph pump will be enough for the gsr motor. I say just stick with your walbro and get it a tune up.</TD></TR></TABLE>
Are you 100% sure on that? I always thought B-series pumps were all the same.
P.S. Since I'm new- they won't let me post anymore for 24 hours sorry for any late responses after this. But at least I can still view your posts so don't hold back. Let it fly.
Old Apr 16, 2004 | 11:36 AM
What does the DX pump flow then?
Old Apr 16, 2004 | 11:56 AM
dantastic's Avatar
i have a b&m fuel pressure guage and 255lph walbro. my fuel pressure is the same as stock: 39psi at idle, 42psi w/ the hose off and pinched. i had the b&m FPR also, but i couldnt get it to set my pressure to within stock specs
SPOOLINmatt
Oct 25, 2012 08:55 AM
Import_2
Oct 23, 2008 08:35 PM
racinskittle
Mar 3, 2003 08:37 AM
Hatchy-Ownzjo0
Nov 19, 2002 10:24 AM
4doorH22
Apr 15, 2002 06:43 PM
