Fuel Pump upgrade time
Old Oct 23, 2012 | 03:25 PM
SPOOLINmatt's Avatar
Default Fuel Pump upgrade time
I have an Aeromotive Pro Pump(biggest available aeromotive) and im running e85. Im currently on the edge of running out of fuel. Im running 4 id2000's and want to make the best use of just the 4 to my abilities. I ran 160mph this past weekend whatever that equates to in HP is getting close to maxing out running 12.0-12.3 afr's
What would be a good upgrade without getting crazy?
was looking at the weldon 2035A, dont know if i can swing the 2345 pump or not, to early to say.
Tickled the idea of the dual bosch, but i think the 2035A flows more than that.
Looking for some of you guys who are running the shizz.
Old Oct 24, 2012 | 05:21 AM
Turbo-LS's Avatar
Default Re: Fuel Pump upgrade time
what base pressure are you starting with and how much boost pressure are you running? What about a magnafuel efi750 pump. there rated to 2000+hp on gas and can run pressures up to 120psi and are more afforable than the weldon units
Old Oct 24, 2012 | 08:21 AM
im up to changes, typically i run about 45 psi with the lines connected. running out of fuel around 35-36 psi
Magnafuel pumps look great but some FLOW DATA on their website would help speed up making educated choices that are informed.
Old Oct 24, 2012 | 06:06 PM
artie89's Avatar
if you need any info call magnafuel
Old Oct 24, 2012 | 09:12 PM
dcmatt's Avatar
Have you considered running a boost a pump?
Old Oct 25, 2012 | 08:55 AM
4cylfiend's Avatar
I think this thread I started will help you out a bit. I was in a similar boat as you. I went with the Magnafuel 4303 because it will support just about all I'll ever throw at it.
https://honda-tech.com/forums/drag-racing-36/fuel-pump-questions-magnafuel-4303-a-3082525/
Originally Posted by 90blackcrx
I have a little information about magnaflow, we're doing a build right now and when we talked to them about the same pump, they said the MP4303 would be good for 1100fwhp on E98 with high combined fuel pressure. I have some more data as well in one of my emails , I just need to dig threw that. The customer opted for a magnaflow because of the price and its a little bit easier to use on a street car. We have them in stock as well so if you're looking to purchase one, contact us.
j0keefe21
14
Oct 15, 2009 12:25 PM
Import_2
Oct 23, 2008 08:35 PM
W.Zero
Dec 12, 2002 03:08 PM
Smoothy
Oct 6, 2001 06:48 AM
