Wiring pictures?
Old Apr 16, 2004 | 07:55 AM
YellowCRXSi's Avatar
Default Wiring pictures?
I have an 89 Crx Si with some light problems. With the lights off when you hit the brake pedal the front marker lights come on with the brakes. When you turn the lights on though the brake lights come on too. They get brighter when you hit the brake but there still on when you release it...including the 3rd brake light.
Does anyone know if a relay could cause this to happen? Thats the only thing i can figure, and which relay would that be? I'm trying to find some photos and descriptions of the fuse box and wiring. Thanx,chris
Old Apr 16, 2004 | 08:03 AM
Wes V's Avatar
Default Re: Wiring pictures? (YellowCRXSi)
First off, get the factory manual for your car from Helmsinc!!
Then use it to verify ALL ground connections to the circuits in question. My bet is on a bad (missing) ground connection that is allowing one circuit to feed into another.
Wes
Nathan_volcom
Jan 30, 2009 10:00 AM
Blackcat_78
Oct 20, 2007 12:20 PM
Surestick
Jun 8, 2006 05:42 AM
.Grimace
Sep 15, 2005 11:23 PM
88Integra
Apr 1, 2005 02:41 PM
