Hatchback brake lights - where do the wires split?
Old 06-06-2006, 06:09 PM
Surestick's Avatar
Default Hatchback brake lights - where do the wires split?
Only one of my three brake lights works.
Bulbs are ok (one's been replaced & the other has an intact filament).
The fuse & pedal switch are ok too (as one lights up that's obvious).
Where do the wires split to connect to their respective brake lights? At the switch or behind the plastic somewhere and if the later, where?
Also, do they share grounds or have seperate grounds?
The wiring diagrams aren't clear: http://www.redpepperracing.com....html
Thanks in advance!
Old 06-06-2006, 06:43 PM
Echo7847's Avatar
Default Re: Hatchback brake lights - where do the wires split? (Surestick)
You need a volt meter, it would make it much easier. Problem may be on the power or ground side.
By the wiring diagram hatch shares 2 grounds, sedan has 1.
I can get a better diagram if I knew what car you had and which of your brake lights work to help you through it.
Old 06-07-2006, 06:27 AM
Surestick's Avatar
Default Re: Hatchback brake lights - where do the wires split? (Echo7847)
It's a '93 Si Hatchback, manual.
The right hand side brake light works, the left side one and the one at the top of the rear window don't.
The rest of the tail lights & indicators work fine including the other filament in the bulbs w/the non-working brake lights.
I have a multimeter, I'm basically trying to narrow down where the problem lies so I can start troubleshooting without pulling out half the interior.
A better diagram would be much appreciated, thanks!
Old 06-07-2006, 04:20 PM
Echo7847's Avatar
Check to make sure you have power coming to each connector and for continuity to ground on the negative side.
Old 06-08-2006, 05:42 AM
Surestick's Avatar
Thanks!
dsurette
Honda CR-V & Element
08-29-2017 03:34 PM
dump3deg6
02-26-2009 05:25 PM
Nathan_volcom
01-30-2009 10:00 AM
Blackcat_78
10-20-2007 12:20 PM
LOWLIFEHATCH
01-30-2004 01:25 PM
Quick Reply: Hatchback brake lights - where do the wires split?
