Code 12:EGR help
Old Apr 16, 2004 | 01:36 AM
blackdelslo's Avatar
Default Code 12:EGR help
Ive got a code 12 which is EGR that only comes on like 5 min after i start the car. Sometimes if I shut it off and turn it back on it will clear and other times it wont. Its not the wiring. Just wondering does this code 12 refer to the EGR valve located on the intake manifold or sensors connected by vacuum hoses?
Old Apr 16, 2004 | 02:31 AM
Behan's Avatar
Default Re: Code 12:EGR help (delLudeVTEC)
code 12 is the egr valve itself ( code 12=EGR valve no action ). Remove the egr and check to see if its clogged/frozen with carbon. IF so cleann out the carbon and reinstall. If not you'll have to replace the egr valve.
Gebo
Nov 1, 2016 09:09 PM
snowblind7x
Jan 28, 2010 07:37 AM
diewX3
Jan 26, 2005 09:22 AM
DC 2
Mar 26, 2004 10:05 PM
