JDM front owners FOg light ?
Old Oct 29, 2001 | 11:59 AM
Double 06's Avatar
New User
Default JDM front owners FOg light ?
What exactly do i need to get the fogs hooked up.. Does the switch have the wiring that goes to the fogs? I don't believe i have any thing in there at all... just wondering....
thanks
Old Oct 29, 2001 | 12:25 PM
Benjamin Tang's Avatar
Default Re: JDM front owners FOg light ? (Double 06)
the switch does not have wiring included. the jdm switch is just like the cruise control button.
i was told by someone else that the integra was already prewired for factory accessory foglights, but i don't know enough to confirm. my shop used a piaa fog light harness and hooked it up independently to a usdm fog light swtich in the center console.
Old Oct 29, 2001 | 03:47 PM
DC2#309's Avatar
New User
Default Re: JDM front owners FOg light ? (Benjamin Tang)
every honda that has an optional foglight in japan are prewired, such as Integra, Civic, Prelude, CRV , just everyhonda i guess.
Old Oct 29, 2001 | 04:00 PM
Mike M's Avatar
Founding Member
Default Re: JDM front owners FOg light ? (DC2#309)
The wire running to the engine bay from the under dash area is a blue wire with brown connectors wrapped to wire harnesses with blue tape. One end is taped to the drivers side light harness, the other is under the dash above the clutch pedal
So no need to run a wire, Now just get a switch, do some wiring to a relay and you'll be set
Old Oct 29, 2001 | 04:37 PM
Double 06's Avatar
New User
Default Re: JDM front owners FOg light ? (TypeRmsm)
thanks, mike, i'm going to check that out right now....
Old Oct 29, 2001 | 04:44 PM
Mike M's Avatar
Founding Member
No problem Wiring the relay is easy also as you can use the accessory taps above the fuse box
Old Oct 29, 2001 | 04:48 PM
05 600RR's Avatar
[QUOTE]The wire running to the engine bay from the under dash area is a blue wire with brown connectors wrapped to wire harnesses with blue tape. One end is taped to the drivers side light harness, the other is under the dash above the clutch pedal
So no need to run a wire, Now just get a switch, do some wiring to a relay and you'll be set [/QUOT
Thats exactly what I did It was very easy to do. The fogs are even suprisingly bright.
Old Oct 29, 2001 | 04:58 PM
Double 06's Avatar
New User
Default Re: JDM front owners FOg light ? (01 ITR 01-0492)
ok, good, i have the blue wire with brown connectors in both the engine bay and under the dash,
Now what i need to do is take the brown connector off, and put it on the new large brown connector that is wired for the rest of the lights, one open connector, that i assume is for the fogs...
then wire the switch into a empty fuse in the fuse block...?
Now where can i get a jdm fog light switch?
Old Oct 29, 2001 | 05:15 PM
Mike M's Avatar
Founding Member
Take off the brown connector, extend the wire to both headlights.
Connect them to the blue wire on the headlights (in the brown connector)
On the inside connect the blue wire to a relays output, connect the input to a constant (+), then connect the relay's solenoid to a ground and to a switched (+) which comes from the fog switch. Connect a source which only has power when the lights are on to the switch. the connections you will need are above the fusebox, use a volt meter to test which is which.
Plenty in stock along with the plug for it
HONDRETTI
Aug 28, 2013 11:00 AM
Rhys!
Jun 26, 2013 03:50 AM
evildragonrsx
Dec 13, 2011 09:41 AM
Wiring Dumbass.
Aug 2, 2010 04:42 PM
michael_c
May 5, 2008 08:38 PM
