ignition?
i just bought a new ecu that is chipped,and it runs a little rich.so i was pondering buying some ignition accessories.i heard that i should go with the msd 6al ignition box and a msd cap and coil.i was wondering what other companies i could choose and determine the best one.i also saw that they have a ignition box made for imports?i am also thinking of getting those denso iriduim spark plug wires with the capacitor and the ground wire built into it.any ideas on my sutuation?thanks for the info
If you use the MSD box then you won't need those spark plug wires b/c that MSD can continue to put out great spark even at high rpm. Unlike your stock distributor that doesn't put 100% at high rpm. Use NGK IRIDUIM plug they are awesome. If you want to lean out your fuel a little so its not running as rich. Get an adjustable fuel pressure regulator and fuel ratio gauge and reduce your fuel pressure. Some times it may actually give you more power. My friend gained about 15hp from leaning his fuel out a little.
