jdm rsx motor
On my ITR I can bounce off the rev-limiter at 8850rpms. I usually shift at like 8750-8800. Everything from Honda on paper says 8400 though.
Now on the other K20As, in the Integra iS it redlines at like 6800rpms. If you plan on buying a JDM K20A, make sure it is from the Type R, as all K20s in Japan are labeled K20A.
Chris
Chris
Should be the valve cover and the intake manifold for the big clues
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie »</TD></TR><TR><TD CLASS="quote">how do you knoe which one has is the type R then? Is it from the redtop?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Should be the valve cover and the intake manifold for the big clues
i see red valve covers on K20a2's all the time...doh
Spoon has ecu's that brings the revlimit from 8000 to 8500 and vtec kicks in at 5600 instead of 5900 check it out at http://www.aj-racing.com alot of spoon stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooligan317 »</TD></TR><TR><TD CLASS="quote">
Red valve cover on a K20A block, is a big clue between the Type-R and iS.
</TD></TR></TABLE>Red valve cover on a K20A block, is a big clue between the Type-R and iS.
breakstylez
123
Apr 26, 2008 10:34 AM
4drferio
May 24, 2005 10:00 PM
