Duration/Lift specs for Stock ITR cams?
Anyone? Make some rude comments or something?
[Modified by Dropspeed, 2:03 PM 10/29/2001]
[Modified by Dropspeed, 6:09 AM 10/30/2001]
Thanks, I found the specs in the service manual last night but I don't know the conversion. It is listed like this:
Duration (lift)
33.088 (1.3027) 36.865 (1.4138) 34.732 (1.3674) intake
32.785 (1.2907) 36.333 (1.4304) 34.691 (1.3658) exhaust
It is for primary low, center is the big(vtec lobe) secondary low. But what is the conversion? .153604?
Mattj
Duration (lift)
Mattj
Those are the total diameter of the cams. It's already in mm (and inches)!!! If you know the diameter of the ground circles, then you can calculate the lift...
) Sorry.
