ITR CAM SPECS
ITR CAM SPECS
Can someone dig up their helms & tell me what the ITR cams lobe height specs are & tolerances. Any & all specs from the book would be much appreciated. My Cams had to be cleaned up (surface rust) & some surface was taken off to do so. I'm trying to make sure they are within spec & are indeed ITR cams. TY!
Re: (HatchSpeeD)
SEarch...I dunno how many times this topic has been buried...
Or for GeEsh sakes... Look at the FAQs section...
https://honda-tech.com/zerothread?id=766629
Re: (Circuit Star-29)
For God sakes! Thanks for making that into such a big deal & not understanding what I was asking anyways. I'm well aware of the lift & duration.
So again, I'm trying to find what the lobe height is & tolerances. What I mean is if the cams were measured with this tool (forgot the name) directly on the cam it would be XXX big. Some surface had to be removed so I needed to know. My builder said he would measure but he doesn't have time to dig up the info or search online for specs. I'll take both older & newer (or CTR) ITR spec in case. BUMP
FSAE
Re: (HatchSpeeD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchSpeeD »</TD></TR><TR><TD CLASS="quote">AWESOME THX! Quick question, is this for 97-99 ITR or 00-01?</TD></TR></TABLE>
Lift is the same between all ITR/CTR cams.
FSAE
Re: (HatchSpeeD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchSpeeD »</TD></TR><TR><TD CLASS="quote">Just the duration changes on the 00-01 ITR or CTR cam on the intake cam?</TD></TR></TABLE>
Yes, by 3 degrees.
Yes, by 3 degrees.
Malice
11-19-2001 11:24 AM
