B16 i cylinder not giving fuel
Old Apr 14, 2004 | 07:41 PM
PhReAzE's Avatar
Default B16 cylinder not giving fuel
OK, heres the situation, i just got my b16 out of the shop, when i first got it i was firing on all cylinders, now i am not firing on the one that is on the drivers side. I checked this by pulling the wires off the dizzy one by one, this one had no effect. The first thing i did was to change the plugs, the one pulled from that cylinder was covered in ****. After the plugs were changed, i still was only firing on 3 cylinders, so i checked the wires, the resistance was acceptable. I pulled the plug again, and put a spark plug on the wire grounded it , and it sparked no prblem. The i realized that there is no fuel going into the cylinder, what do i do next? what do i check?
Thanks, Evan
Report Post | IP: Logged
Modified by PhReAzE at 7:03 AM 4/16/2004
Old Apr 14, 2004 | 07:51 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Check your injector... That's the only thing it could be. And get a known good wire on there just in case...
turboedek96819
Apr 5, 2015 06:14 PM
thunderboy
Apr 24, 2010 08:39 AM
jvillagran2000
15
Dec 2, 2008 02:03 PM
PhReAzE
Apr 16, 2004 10:41 AM
A_W_D_Turbo
Feb 8, 2003 05:22 PM
