***People with vtec motors with no vtec ECU i got a Q***
Old Apr 14, 2004 | 06:40 PM
showtymers619's Avatar
* B A N N E D *
Default ***People with vtec motors with no vtec ECU i got a Q***
since you have a vtec motor .. and dont have a vtec ecu .... who did you make your vtec turn on...
i kno you can use a vtec controller.. but what do you use to activate the oil pressure switch?
can you guys point me toa site or on a how to .. or parts i would need..
Old Apr 14, 2004 | 06:59 PM
IMALLSLO's Avatar
Default Re: ***People with vtec motors with no vtec ECU i got a Q*** (ShowTymers619)
No need for the oil pressure switch/sensor. Your only concern is the solenoid. IMHO you should just spend the $$$$ and do it the right way. Go buy a VTEC ecu and hook it up correctly. The advantages of a Vtec ecu is the fuel,map and timing curves you gain when Vtec kicks in. When you hard wire it all you are doing is turning on a switch activating Vtec.
Old Apr 14, 2004 | 08:36 PM
* B A N N E D *
Default Re: ***People with vtec motors with no vtec ECU i got a Q*** (IMALLSLO)
well the thing is.. its my little CRV b20 vtec project... i cant really find a automatic gsr ecu.. or a automatic b16 ecu...the only thing i have is the vafc...
why dont i need to hook up the pressure switch?i thought i needed to hook that up
Old Apr 14, 2004 | 08:49 PM
kid-honda's Avatar
They did make auto OBD 0 B16 ECU's so do it right or dont waste your time.
Old Apr 14, 2004 | 10:26 PM
Fobtions's Avatar
Default Re: (kid-honda)
get yourself the ecu , so vtec will work how it was meant for
majority of the pr3's are automatic.
stay away from pw0 since they are mostly manual.
Old Apr 14, 2004 | 11:00 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">They did make auto OBD 0 B16 ECU's so do it right or dont waste your time.</TD></TR></TABLE>
this is a CRV its obd2 the motor is still in the CRV LOL im usin gthe CRV its not a swap
vtechaccord
Mar 14, 2011 03:03 PM
tgjg19
Aug 17, 2009 07:41 PM
digitalhav0c
Apr 9, 2002 11:05 AM
vspec12
Nov 5, 2001 05:25 AM
[626] SiRJKwIcK89Ef
Oct 10, 2001 06:37 AM
