will ctr intake cam work good with stock gsr exhaust cam?
Old Apr 14, 2004 | 04:52 PM
theslugbug's Avatar
Default will ctr intake cam work good with stock gsr exhaust cam?
will it work perfectly fine or will the timing be off? ctr int and gsr exh. or should i get an exh ctr cam too. let me know whats up.
im hoping that i can just run on ctr int and gsr exh. let me know what u know with ur experince or knowledge.
Old Apr 14, 2004 | 05:03 PM
hotintegranights's Avatar
Default Re: will ctr intake cam work good with stock gsr exhaust cam? (alllgo)
it will not affect timing. gsr exhaust cam is just slighly less aggressive than the ctr/itr exhaust cam so your not loosing much, the real advantage is the intake cam which you already have
Old Apr 14, 2004 | 05:30 PM
theslugbug's Avatar
Default Re: will ctr intake cam work good with stock gsr exhaust cam? (hotintegranights)
cool, thanks for the info. any one else with info on this?
Old Apr 14, 2004 | 05:40 PM
fuck honda-tech's Avatar
should work great, just make sure to keep stock rev limit. unless you plan on upgrading valvtrain!
Old Apr 14, 2004 | 05:42 PM
dfoxengr's Avatar
itll be fine
Old Jun 20, 2004 | 06:13 AM
BrokeAssWhiteboy's Avatar
my house has wheels on it
what kind of gains could you expect out of that? also would you need to raise crossover to 5700 like the ctr has or will the stock gsr crossover work without bogging the engine?
Old Jun 20, 2004 | 08:34 AM
dfoxengr's Avatar
Default Re: (BrokeAssWhiteboy)
hit the dyno to find gains and vtec points
Shartek
Jun 28, 2008 03:38 PM
BMo Tuning
May 8, 2008 12:13 PM
racerboyb16
Oct 10, 2002 10:55 PM
Weslay
Mar 4, 2002 10:16 AM
