ECU upgrade witch 2 go with? And where?
Old Apr 14, 2004 | 03:42 PM
lobttm2's Avatar
Default ECU upgrade witch 2 go with? And where?
Fellas, Trying to upgrade the ECU to rev @ 9500 and try to move the VTEC to about 4100-4400 along with changing the fuel curve and timing a bit.
My MODS :
S2 I/M , S2 Stage1 Cams and Valve train, 68mm T/B STR , AEM fuel rail and reg, headers, exhaust and s2 cam gears.
weather I chip it or piggy back it I need a website I could go to ....
Thnx
Old Apr 14, 2004 | 03:52 PM
zensoku207's Avatar
Drop an IM on here to IH8ricerz, he does chipping for ecus, and can make it to pretty much whatever u want.
Old May 6, 2004 | 07:22 AM
Accordmad's Avatar
I am about to get this, the gains are pretty good on the dyno
http://cgi.ebay.com/ws/eBayISA...=WDVW
Old May 6, 2004 | 08:20 AM
Joseph Davis's Avatar
Default Re: (Accordmad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accordmad &raquo;</TD></TR><TR><TD CLASS="quote">I am about to get this, the gains are pretty good on the dyno
http://cgi.ebay.com/ws/eBayISA...=WDVW</TD></TR></TABLE>
I've seen JET chipped OBD1 ECU that they never set the J1 jumper on - meaning the car wasn't running off the chip. I've heard stories of stock OBD2 ECUs that get the JET sticker for $$$ treatment - you pull the cover and it's still running the stock un-reflashable 66P589 MCU. Chipping of OBD2 would require the MCU to be removed/replaced in a visible manner or preferrably removed/replaced (in a visible manner) with a 66Q589 that you can reflash as needed.
JET also has a very poor reputation among the domestic community. I cannot recommend strongly enough to stay away.
Find a good independant chipper to take care of your needs... there are only seven dozen or so on HT.
Old May 6, 2004 | 09:41 PM
iH8RICERZ's Avatar
Default Re: ECU upgrade witch 2 go with? And where? (lobttm2)
Thanks for the referel zensoku207
I'd be happy to help you out...dont go with that JET garbage...if you do your research, you wont find very many happy/satisfied customers......
pm me for more info
vtec killin
Jun 25, 2007 09:25 AM
2SlowDC
Nov 21, 2005 11:14 PM
Autoworks
Jul 30, 2005 04:59 AM
Ragecloak
Feb 17, 2005 12:04 AM
redddevil
Mar 20, 2004 05:31 AM
