weird sound when i turn
Old Apr 14, 2004 | 02:57 PM
hyperlite1080's Avatar
Default weird sound when i turn
When I turn really slowly I hear a bunch of clicking almost light popping. It only happens when i have the wheel cranked all the way to the right, and sometimes to the left. I replaced my passenger side axle, I thought it might be my drivers side now, but i'm not sure. It also could be suspension, but i'm not sure. I am sure it isn't a ball joint or any of my control arm bushings cus i just replaced them hoping to solve the noise. It doesn't bother me, other than I don't want my car to fall apart when i'm going fast.
Old Apr 14, 2004 | 03:02 PM
RCautoworks's Avatar
Default Re: weird sound when i turn (hyperlite1080)
Go find a huge parking lot, start driving in a circle. First turn the wheel to the right and drive in a circle, then turn the wheel to the left and drive in a circle. If you here the noise, what ever way your turning thats the side the axle is bad on or is going bad.
Old Apr 14, 2004 | 03:32 PM
Me2's Avatar
Me2
Cv axles Jackass
Old Apr 14, 2004 | 03:34 PM
HatchBox's Avatar
Skoobie no more...
Default Re: weird sound when i turn (Me2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Me2 &raquo;</TD></TR><TR><TD CLASS="quote">Cv axles Jackass</TD></TR></TABLE>
not everyone is as smart as you Jackass
deffinatly your axles do what 90blackcrx said and replace that axle and you should be good
Old Apr 14, 2004 | 03:47 PM
CRXNuts's Avatar
Default Re: weird sound when i turn (Hybrid Hatchback)
It is your constant-velocity axle (CV). Also known as a driveshaft at most auto-retail shops like autozone, napa, advance, oreilly's etc.
Best way to make sure is to slip your hand underneath the car and go behind each front wheel. Very close to the wheel and brake assemblies is a rubber boot (sheath/covering). Use your fingers and give it a good all around feel (remember the first time in the back seat, yeah, imagine something like that). If you notice tears in the boot, and it is spitting out grease, you need a new axle. I'd recommend replacing axles over replacing boots as road dirt and grime contaminate the grease as soon the boot is torn, eventually, even with replacing the boot, the axle is toast.
Most auto-repair shops like Midas, carX, Meineke and Firestone charged on average $150-$200 to replace them. A good friend will do them for 20-50. The axle costs around 50-70. Best of luck.
Have a nice day.
Old Apr 14, 2004 | 03:55 PM
I3ackfire's Avatar
Lol, that is probably what it is, but dont gotta be so rude now do you...
Old Apr 14, 2004 | 04:02 PM
EF9Dreams's Avatar
Default Re: weird sound when i turn (I3ackfire)
axles
Old Apr 14, 2004 | 05:41 PM
B1TEM3's Avatar
Default Re: weird sound when i turn (EF9Dreams)
$20 from used one and $40 brand new, i bought the new CV joint.
Old Apr 14, 2004 | 06:11 PM
blah13's Avatar
Default Re: weird sound when i turn (B1TEM3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B1TEM3 &raquo;</TD></TR><TR><TD CLASS="quote">$20 from used one and $40 brand new, i bought the new CV joint.</TD></TR></TABLE>
You can do either just the joint or the whole axle...me personally, I'd grab the lifetime autozone axle deal....I've never done a CV joint change but changing an axle isnt very hard, I'd stick with what I know.
Old Apr 14, 2004 | 07:17 PM
That is what i figured it was, just didn't want to spend the money, i want to get my Supercharger. Thanks for the info, by the way ME2 your an *** man, why don't you figure something else to do then correct people on their mistakes. I guess i'll be putting in a new axle.
Old Apr 14, 2004 | 07:56 PM
sloweh3's Avatar
Default Re: (hyperlite1080)
Yep, it's your axle alright. Just remember, if you hear clicking when you cut the wheel to the right, it's the driver side axle. It's always opposite of which way your wheel is turned.
Old Apr 14, 2004 | 08:24 PM
B1TEM3's Avatar
I drive on highway all the time, get the new one, its critical part for safety
Toadfart
Jan 26, 2005 08:22 PM
EKlat_9
13
Aug 8, 2004 06:29 PM
stockegsix
May 27, 2004 04:52 AM
WhitEdRift
Mar 11, 2004 08:48 PM
AGPSuperstar
11
Feb 13, 2003 04:44 PM
