Thump when turning and accelerating.
Old Jan 16, 2005 | 10:43 AM
Toadfart's Avatar
Default Thump when turning and accelerating.
I get a weird thump or clunk from the drivers side when the steering wheel is turned to make a right turn. It doesn't clunk when cruising into the turn, but if I accelerate from a stop or accelerate into a right turn it clunks. Started happening after replacing my clutch. Any suggestions?
Dan
Old Jan 16, 2005 | 01:25 PM
daLixz25's Avatar
Take a look at your CV boots. If they're busted, you'll have a clicking noise when you turn the steering wheel.
Old Jan 16, 2005 | 03:58 PM
Toadfart's Avatar
Default Re: (daLixz25)
It's not the CV boots and its not a repetitive click. Just one single thump.
Old Jan 16, 2005 | 04:06 PM
MolecularIntegra's Avatar
Default Re: (Toadfart)
Your CV boot doesn't have to be messed up at all for the axle to be bad.
Old Jan 16, 2005 | 04:33 PM
BremertonDA's Avatar
From: Bremerton, Washington, United States of America
Are your lug nights tight?
Old Jan 17, 2005 | 05:39 AM
JimBlake's Avatar
Default Re: (BremertonDA)
Maybe a ball joint getting loose??
Old Jan 17, 2005 | 11:28 AM
laezpnai's Avatar
Default Re: (JimBlake)
i had the same problem turning left and posted a million times about it and got no help other than cv boot .. iOno tho, because it went away, only happens once in great while now.. *shrugs* i know i still need to figure it out tho
Old Jan 17, 2005 | 12:28 PM
importdude2000's Avatar
i have that thumb when stoping/ accel in 1st gear for the frist 2k rpm
its not axles becuase i replace em 2 times
Old Jan 17, 2005 | 07:17 PM
Toadfart's Avatar
Default Re: (importdude2000)
Was thinknig about replacing axles. Good input guys, keep em coming...
Old Jan 17, 2005 | 07:37 PM
xscape's Avatar
I have a clunk coming from the left wheel when making tight slow turns (i.e parking).. it clunks at a particular spot, probably after one full turn or so.. and clunks again on the way back.
its a metalic type of sound, kinda like DING CLUNK with a bit of SCRAPE in between.
any ideas? i've always thought CV but now i think its something worse, its quite loud too.
Old Jan 17, 2005 | 10:22 PM
Toadfart's Avatar
Default Re: (xscape)
That's exactcly how I would describe the noise except without the scrape noise.
Old Jan 18, 2005 | 03:55 AM
JimBlake's Avatar
Nothing says it has to be the same thing on all your different cars, either. Drive up on ramps & look for loose bolts. Maybe loose bolts holding a subframe? Maybe loose inboard mounting points for control arms? Maybe anti-roll bar endlinks are loose?? You're each gonna have to look at all that stuff until you find something loose.
Old Jan 18, 2005 | 09:04 PM
Toadfart's Avatar
Jacking the car up tomorrow morning. Will keep you posted.
Old Jan 19, 2005 | 04:36 AM
JimBlake's Avatar
Sometimes jacking it can hide the problem. For example if a shock is getting flaky, you can jack it up & the shock will be stretched out to it's max & you can't tell it's loose. Got ramps?
Old Jan 26, 2005 | 08:22 PM
Toadfart's Avatar
T'was the axles yay! Felt like the CV joint was really loose. $69 bucks for the axle w/ lifetime warranty!
cmkwood
Dec 14, 2013 05:37 AM
VTECdohcter
Feb 14, 2009 07:50 PM
Jizzmaster Zero
12
Jun 16, 2006 02:42 PM
Civicracer17
Mar 17, 2006 06:21 PM
AGPSuperstar
11
Feb 13, 2003 04:44 PM
