Replace my O2 sensor?
Old Oct 29, 2001 | 01:27 AM
Rain_man's Avatar
New User
Default Replace my O2 sensor?
I keep seeing that O2 sensors should be replaced every 60k. Well I have almost 100k, so should I replace it?
Old Oct 29, 2001 | 03:42 AM
Roach2k's Avatar
New User
Default Re: Replace my O2 sensor? (Ein)
well yeah probably if that's the case...
Old Oct 29, 2001 | 09:47 AM
88_SC_CRX_Si's Avatar
New User
O2 sensors do not wear out..... They just get clogged up from various reasons. As long as your not getting any kind of code, or running rich, it should be alright. They have been known to last the entire lifetime of a car. When it has been properly maintained.
Old Oct 29, 2001 | 05:20 PM
fixhondas's Avatar
There is no specified time for replacement of the O2 sensors. Some last 20,000 miles and some last 200,000 miles. IT depends on what you consider bad. An O2 can have good voltage but slow response or it can have good response and poor voltage. If you have a graphing meter you can see how good your O2 is. If you do replace it, get a honda piece (denso or ngk) bosch O2's for Hondas suck. I personally replace mine around 120k if I have the money, I also change my TW sensor at the same time. Sensors tend to deteriorate over time, and they affect performance. The ECU can only run the engine as good as its sensors tell it.
Old Oct 29, 2001 | 05:25 PM
G's Avatar
G
Default Re: Replace my O2 sensor? (fixhondas)
Whats a TW sensor? If all else is unchanged and you notice a decrease in mileage, an o2 sensor would be suspect..........
Old Oct 29, 2001 | 05:32 PM
fixhondas's Avatar
Default Re: Replace my O2 sensor? (G)
The TW sensor is actually the ECT sensor. Honda calls it the TW which means water temp or something. This sensor is one of the most important sensors when it comes to determining fuel delivery. A cold engine needs lots of fuel. I would say that the TW sensor is just as important as a MAP sensor. It deteriorates over time and becomes less accurate. I changed my TW and O2 around 120k miles and you wouldn't believe the improvement. I see many cars that wont start because of an inaccururate TW. The O2 signal allows the ecu to really fine tune the mixture and control idle speed on decel.
Old Oct 29, 2001 | 06:17 PM
G's Avatar
G
Thanks, I was wondering if it was temp water backwards..... It was, I get a brownie!
s2k drifter
Mar 30, 2005 01:11 PM
boost fed ls
Aug 31, 2004 07:45 PM
Shakes
Apr 28, 2004 08:45 PM
Rain_man
Oct 29, 2001 09:27 AM
