Mysterious Defi gauge problem
Old Apr 14, 2004 | 02:25 PM
Project X's Avatar
Default Mysterious Defi gauge problem
I'm having this problem with my Defi electrical oil temperature gauge.
When the key is in ACC, the gauge will already be up in the 100C. After the car has started, it will be slowly moving up until it reaches just beyond max and stay there. Sometimes, it will suddenly sweep wildly back and forth and drops to 0C.
I know there is nothing wrong with my oil temperature. The initial check-up sequence indicates that the gauge is normal.
What is causing this problem?
- bad ground?
- bad controller unit?
- bad sensor?
Old Apr 14, 2004 | 02:27 PM
JDM CTR '00's Avatar
Default Re: Mysterious Defi gauge problem (Project X)
Check all the wires make sure it's not loose or pinched...
Old Apr 14, 2004 | 07:48 PM
Philly_NBP_R's Avatar
Default Re: Mysterious Defi gauge problem (JDM CTR '00)
had this exact problem with my Greddy gauges - you need to hook up the constant DC power to the gauge - any constant, unswitched power source will work, but it needs to stay on, even if the car is shutoff. I used a circuit /fuse sharing thing and tapped into the power door lock circuit on the fusebox - has worked perfectly since. PM me if you need any more help...
The gauges use the constant power to self-calibrate, and without it, they will act really strange. You obviously also need to hook up switched power as well - make sure you follow the wiring diagrams that should have come with your gauges.
Old Apr 14, 2004 | 08:43 PM
Project X's Avatar
Default Re: Mysterious Defi gauge problem (Philly_NBP_R)
The funny thing is that my other gauges (oil press and water temp) work fine. Since they are daisy-chained, should either all or none of them work?
Old Apr 18, 2004 | 03:08 PM
IntegraXTR's Avatar
bump..
getting oil pressure and oil temp gauges from defi as well..
i have a greddy oil filter relocation kit, these will work right?
and as far as the temp gauges is concerned..shouldn't you be able to line it with a constant fuse?
Old Apr 19, 2004 | 04:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project X &raquo;</TD></TR><TR><TD CLASS="quote">The funny thing is that my other gauges (oil press and water temp) work fine. Since they are daisy-chained, should either all or none of them work?</TD></TR></TABLE>
some gauges will work without the constant power, and some won't. When I wired mine up wrong, on the oil pressure worked, and the temp was acting all goofy. Just double check that you wired up constant AND switched power to the gauges per the instructions...
Old Apr 19, 2004 | 12:47 PM
Project X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">
some gauges will work without the constant power, and some won't. When I wired mine up wrong, on the oil pressure worked, and the temp was acting all goofy. Just double check that you wired up constant AND switched power to the gauges per the instructions...</TD></TR></TABLE>
Another thing is that all 3 worked fine before. This problem just happened recently.
Old Apr 19, 2004 | 01:47 PM
IntegraXTR's Avatar
hmm...well, i'm gonna get some defi gauges soon...i'll have to report back to see what's the problem =P
abmerop18
Jul 21, 2009 01:16 PM
- Sim -
Sep 22, 2004 09:44 AM
tthame1
Jun 17, 2004 06:06 PM
Jays91DXhatch
Jun 7, 2004 09:20 PM
