Charging system problems
Old Apr 14, 2004 | 11:14 AM
defvayne's Avatar
Default Charging system problems
Ok, i need major help. I have changed the alternator on my car 3 times and it does not charge the battery. Everytime i drive it and go past 4k rpms the battery light comes on. I have checked the fuse the controls the alternator and its fine. Has anyone had this problem before.
Old Apr 14, 2004 | 11:27 AM
defvayne's Avatar
Default Re: Charging system problems (defvayne)
bump....someone help please.
Old Apr 14, 2004 | 11:29 AM
JDMlyfestyle's Avatar
did u put the ground cable on the altenator?
Old Apr 14, 2004 | 11:47 AM
defvayne's Avatar
Default Re: (JDMlifestyle)
yeah i have the ground cable to the alternator. someone told me to check the belt tension, might that doit?
Old Apr 14, 2004 | 11:50 AM
JimmyAtlantis's Avatar
Default Re: (defvayne)
Clean every last connection that has to do with the charging system. 10 to 1 you didn't need to buy a new alternator in the first place.
Old Apr 14, 2004 | 11:52 AM
defvayne's Avatar
Default Re: (JRI94)
i cleaned it out, and the alternator i had on there before was bad. but the thing that is trippy is the battery light turns on in the gauge cluster when i go over 4k rpms.
Old Apr 14, 2004 | 11:59 AM
yup sounds like u got a loose belt. its probably moving too fast after 4 k that its not even grabbing the pulley
Old Apr 14, 2004 | 12:33 PM
monicle's Avatar
are you sure you didnt install a super dooper vtec light on your charge system light in your cluster?
Spencerk10
Sep 13, 2015 08:48 PM
sixgunsound
Jun 7, 2009 05:45 PM
rex714
Nov 19, 2008 12:13 PM
haywyre
Oct 9, 2008 12:27 PM
fe519
Sep 23, 2003 03:25 AM
