"mini-me" swap D15B7 leftover heads.
Old Apr 13, 2004 | 09:14 PM
civicdx94's Avatar
Default "mini-me" swap D15B7 leftover heads.
Does anybody that has done the Mini-me swap on a d15b-series have a stock head to sell? I am looking for a cheap- replacement head. My 94 civic DX's d15b7 head, I believe, has a stuck or sticking exhaust valve and needs valve seals anyway.
The previous owner ran the engine with one bumm plug for months (yeah thats right, only 3 cylinders firing) I replaced the spark plug, got a new cap and rotor, air filter is new, also has new wires. I readjusted the valve lash ( the valve cover had never been off in 155K miles). The engine ran better and smooths out as soon as I leave a stop sign, but I still have what feels like a bad miss sitting still with the tranny in gear. any ideas?
I noticed when I took the oil filler cap off while it was running that there was a lot of air coming out of the valve cover, not smokey, but a lot. Is this normal for a 4 cyl honda? This is my first civic, but I do have a 2000 Odyessy (spelling?) as well.
Any advice for a newbie? (well to civics, anyway. I'm used to my truck, '88 f150 EXT cab 4x4 5.8L (351 cid) EFI V8 (no replacement for displacement).
Thanks in advance!
Old Apr 13, 2004 | 09:46 PM
boredracer408's Avatar
Default Re: "mini-me" swap D15B7 leftover heads. (civicdx94)
message sent
Old Apr 13, 2004 | 09:48 PM
Tad's Avatar
Tad
why dont you just go all the way and do a minime swap?
if your d15b7 head is arleady fuct, might as well upgrade it while ur swapin?
Old Apr 13, 2004 | 09:51 PM
BauleyCivic's Avatar
Risky Business
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just go all the way and do a minime swap?
if your d15b7 head is arleady fuct, might as well upgrade it while ur swapin?</TD></TR></TABLE>
Because you gotta change the timing belt, ECU, and ish...not worth the hassle unless you really wanna do it.
Old Apr 13, 2004 | 10:06 PM
HatchEG92's Avatar
Default Re: (BauleyCivic)
if your swapping heads you should change the timing belt anyways...
Old Apr 13, 2004 | 10:09 PM
95cxhatch's Avatar
Default Re: (HatchEG92)
i'll have one soon...gotta an entire JDM D15B with Si tranny going in next week, so i'll have a B7 tranny and complete motor, and ECU if anyone is looking for parts......cylinder #2 has piston "SLAP"....
Maddvtec
Dec 17, 2010 08:53 AM
ITLNstallion818
Oct 12, 2008 05:08 PM
92egintheham
Mar 19, 2006 11:47 AM
Muckman
Oct 27, 2003 09:42 PM
