Compression Test on motor out of the car??
Old Oct 28, 2001 | 05:50 PM
DR. ON POINT's Avatar
Banned
Default Compression Test on motor out of the car??
Any one know how to do this??
Old Oct 28, 2001 | 06:31 PM
Mike K's Avatar
Default Re: Compression Test on motor out of the car?? (On Point)
i've never done it.. but you should be able to hook up power and ground to the starter and it'll crank. have someone hold the cables to the starter and another person hold the throttle open. anyone else?
i would think this will do it
Old Oct 28, 2001 | 06:38 PM
lotus's Avatar
New User
Default Re: Compression Test on motor out of the car?? (Mike K)
Wreckers do it that way all of the time.. no worries
Old Oct 28, 2001 | 08:33 PM
FAST94GSR's Avatar
New User
Default Re: Compression Test on motor out of the car?? (lotus)
yep that should do it. Dont' forget to remove all the spark plugs out.
Old Oct 28, 2001 | 08:36 PM
HX_Guy's Avatar
Default Re: Compression Test on motor out of the car?? (FAST94GSR)
Yea...what if there is no tranny connected to the engine? That wont work.
I think as someone said it another forum...you can crank the engine over with a socket/rachet.
[Modified by HX_Guy, 9:36 PM 10/28/2001]
Old Oct 29, 2001 | 05:38 AM
Mike K's Avatar
Default Re: Compression Test on motor out of the car?? (HX_Guy)
If it's a high compression motor, you better have forearms like Arnold Schwarzenegger!
Old Oct 29, 2001 | 07:02 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
do a leakdown test. i work at a wrecking yard and we do it all the time on the good motors. take the motor to a reputable mechanic and have him do it for you. shouldn't cost more than $50 to $100.
Old Oct 29, 2001 | 09:41 AM
bojangs's Avatar
New User
you forgot "someone to hold the motor" so it doesn't lunge off the engine stand!! we did this a few years ago no prob.. it's kewl seeing your motor firing while sittin on a stand!
DropSide
Apr 18, 2007 06:22 PM
stripes777
Mar 17, 2004 08:34 AM
NOSed_b18b
Jan 20, 2003 10:54 AM
JDMEMM
Oct 21, 2002 10:56 PM
