Ok a few questions AFTER the Profec B and Tial Wastegate install...My boost wont go over 5psi...??
After I have got everything put in. I noticed that I cant raise my boost to over 5 psi. Was I not suposed to put that little ring thing in there if I was using the profec b? Also how far do you have to turn the low boost **** to get any more boost to come up? Thanks...
did you hook it up like i told you here? https://honda-tech.com/zerothread?id=83057
consider you've hook it up right. Ajust the sharpness a little to the sharp side, that should do it.
hybridcrx
Jul 23, 2002 08:07 AM
TurboIntegra
Aug 11, 2001 01:23 PM
