crx b18c5 question ecu
Old Apr 13, 2004 | 10:55 AM
mini-cRx's Avatar
Default crx b18c5 question ecu
i was wondering by using the p73 it islike a pre obd but is plugs for obd2 so how do the sensors work and isnt obd1 better for tuning and other stuff any info helpful tahnsk guys
Old Apr 13, 2004 | 11:00 AM
mini-cRx's Avatar
Default Re: crx b18c5 question ecu (mini-cRx)
What did you do for:
Fuel tank Pressure Sensor?
Charcol Canister sensor?
Secondairy O2?
And all the other BS OBD2 sensor?
Or are you running a JDM ITR ECU so it doesn't use those???
like how does this all come in to play if you were gone use a hondata or just areg ecu or is it better to not have to run this stuff with the jdm ecu
Old Apr 14, 2004 | 01:14 PM
mini-cRx's Avatar
ttt
Old Apr 14, 2004 | 01:45 PM
kron0ne's Avatar
not too sure but if you search you might fiond something...correct me if im wrong...
use a PR3 and run it OBD0
Greg S.
Old Apr 15, 2004 | 09:08 PM
StorminMatt's Avatar
Default Re: crx b18c5 question ecu (lsi crx)
The JDM P73 actually uses OBDII-style plugs. But it only looks for OBDI sensors. As such, the difficulty level of changing the plugs is about the same as changing to 1992-1995 plugs. Except this ECU looks for neither a VTEC pressure switch nor a purge valve.
The USDM P73, on the other hand, it s true OBDII ECU. And it is going to be a pain to wire up. But it will be necessary to use this ECU in order to be smog legal if you live in California.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsi crx &raquo;</TD></TR><TR><TD CLASS="quote">not too sure but if you search you might fiond something...correct me if im wrong...
Greg S.</TD></TR></TABLE>
Keep in mind that if you do this:
1. The fuel maps are not going to be right. You will have to reprogram, which will cost quite a bit of money. It is MUCH cheaper to use the P73 that came with the motor and wire it up.
2. You will have to deal with that retarded twin oxygen sensor setup. The P73 uses a four wire sensor. But at least there is only one. And you won't have to butcher that nice, new header you just got to weld in a couple of ugly oxygen sensor bungs. Four wire osygen sensors are also ALOT more reliable and give better fuel economy.
3. Use of a PR3 requires a pre-1992 distributer. This will be somewhat expensive and troublesome to procure. They are also MUCH more prone to failure than the 1996+ distributer that comes with a B18C5.
4. Emission legality is going to be a BIG problem if you live in California. You are even more likely to pass if you try to take your car to a ref with the JDM P73!
I don't know why people still try to halfass it with pre-1992 ECUs on later motors just for the sake of easier wiring.
Old Apr 15, 2004 | 09:37 PM
kid-honda's Avatar
Default Re: crx b18c5 question ecu (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
I don't know why people still try to halfass it with pre-1992 ECUs on later motors just for the sake of easier wiring.</TD></TR></TABLE>
Cause all they care about is seeing the word VTEC on the valve cover not the performence.
em1xiong
Engine Management and Tuning
Dec 31, 2014 07:36 AM
wushubrian
Jan 24, 2007 09:37 AM
Declectic
Nov 27, 2004 05:33 AM
rice4life
Nov 26, 2003 10:34 AM
