PCV help
Old Apr 13, 2004 | 07:10 AM
AutoXer's Avatar
Default PCV help
How do I access the PCV to replace it? I know where it is, but I'm not sure how to get to it since it's sort of under the manifold. Can i just pull it through the cut out in the IM? Is there a DIY for this?
This is on a D16Y8
Old Apr 13, 2004 | 07:16 AM
SOHC_MShue's Avatar
Default Re: PCV help (EX_AutoXer)
jack your car up and get under there if you have to.
Old Apr 13, 2004 | 07:19 AM
AutoXer's Avatar
Default Re: PCV help (SOHC_MShue)
I had it jacked up to do some other stuff, but I couldn't really get to it. I suppose I'll try that again. I had so much other work to do on the car that I only spent about 5 minutes trying to access it. I figured I'd try again some other time. The service manual wasn't much help, it just shows you where it is and says remove it.
Old Apr 13, 2004 | 08:43 AM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">I had it jacked up to do some other stuff, but I couldn't really get to it. I suppose I'll try that again. I had so much other work to do on the car that I only spent about 5 minutes trying to access it. I figured I'd try again some other time. The service manual wasn't much help, it just shows you where it is and says remove it. </TD></TR></TABLE>
Remove you intake manifold and you will be able to reach it without a problem. Or do it the lazy way and get a set of bent needle nose pliers and try to reach it that way.
Old Apr 13, 2004 | 11:29 AM
AutoXer's Avatar
Default Re: PCV help (JDM-EGGROLL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EGGROLL &raquo;</TD></TR><TR><TD CLASS="quote">
Remove you intake manifold and you will be able to reach it without a problem. Or do it the lazy way and get a set of bent needle nose pliers and try to reach it that way.</TD></TR></TABLE>
I'd need a new gasket if i took the mani off, right? I may just try the pliers...
pfcle
Honda Civic (2006 - 2015)
May 30, 2007 09:13 PM
Photik
Jun 27, 2006 01:30 PM
b18cEK
Mar 16, 2006 01:54 PM
Mr. Vapor
Dec 30, 2005 07:53 AM
accordsil2
Audio / Security / Video
Jun 29, 2003 07:10 PM
