INJECTOR SIZE
The first thing I check was the plugs and one was loose. After that I thought everything was fine. I stareted the car and it was a little better than before, but it was still a little bit ruff on the idle. It actually sounds like something was disconnected that's when I check each injector. What is cel.
I know that to you it seems that an injector is bad, but have you re-gapped/replaced the plugs along with a fresh cap and rotor (maybe even a plug wire is on the blink). Any of which could lead to a rough idle.
You could also send all your injectors out to RC Engineering and have them cleaned/balanced. Come to think of it, maybe that's something I should do to my car soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer rick »</TD></TR><TR><TD CLASS="quote">The first thing I check was the plugs and one was loose. </TD></TR></TABLE>
I bet its fouled.
Swap the plugs around and then do the 'injector test'
I bet its fouled.
