tooHELP!!!
Old Apr 12, 2004 | 11:38 PM
jdmitr01's Avatar
Default HELP!!!
The engine light came out.. I dont add intake or header on the motor.. I check the oil and it look clean.. How should I take the light out? I already took the battery cable off and then put it back on.. Later, the engine light came on again.. What can I do?
Old Apr 12, 2004 | 11:49 PM
Kendall's Avatar
Check it to see what code it's throwing. If you can't check it, then take it to a shop that can.
Old Apr 13, 2004 | 12:21 AM
Boges's Avatar
Default Re: HELP!!! (jdmitr01)
Everything you need to know about CEL's: http://www.c-speedracing.com/faq/06.php
Old Apr 13, 2004 | 05:29 AM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr01 &raquo;</TD></TR><TR><TD CLASS="quote">The engine light came out.. I dont add intake or header on the motor.. I check the oil and it look clean.. How should I take the light out? I already took the battery cable off and then put it back on.. Later, the engine light came on again.. What can I do?</TD></TR></TABLE>
The Check Engine light is there to help you. Check the code it is throwing so you know why the light is on, don't just try to turn it off and hope nothing is wrong.
sherman
Honda S2000
13
Jun 22, 2006 04:13 PM
oneforce
Mar 10, 2005 12:02 PM
B18CR-X
Mar 27, 2004 06:38 AM
laurat
Oct 14, 2002 12:54 PM
VTECVillain
Jan 6, 2002 11:40 AM
