tooHELP!!!
The engine light came out.. I dont add intake or header on the motor.. I check the oil and it look clean.. How should I take the light out? I already took the battery cable off and then put it back on.. Later, the engine light came on again.. What can I do?
Everything you need to know about CEL's: http://www.c-speedracing.com/faq/06.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr01 »</TD></TR><TR><TD CLASS="quote">The engine light came out.. I dont add intake or header on the motor.. I check the oil and it look clean.. How should I take the light out? I already took the battery cable off and then put it back on.. Later, the engine light came on again.. What can I do?</TD></TR></TABLE>
The Check Engine light is there to help you. Check the code it is throwing so you know why the light is on, don't just try to turn it off and hope nothing is wrong.
